Sponsored by: Real Truck
08 gauge cluster
Old Jul 15, 2024 | 10:37 AM
Nightmare90gt's Avatar
Nightmare90gt
08 gauge cluster
I am doing a 2013 platinum swap on my truck. I was wondering since I can’t run the 6.7 cluster is there a way to swap the lighting from green to white on the cluster? Or run the 6.7 gauge face in place of the 6.4?
Old Jul 15, 2024 | 06:04 PM
ifrythings's Avatar
ifrythings
You could manually unsolder each led and swap them but that’s a lot of work and a high probability you’ll wreck the leds and circuit board. I don’t believe you can swap the gauge faces either as they are different, even if you did it would still be green from the 08 LEDs as most of the gauge faces are non tinted.
Old Jul 16, 2024 | 04:28 PM
Tpayne621's Avatar
Tpayne621
I did 6.4 dash and interior in my 99 with a 6.7 cluster. I had to change the leds in all my door switches and headlight switches and ac switches to the aqua blue to match the 6.7 stuff. I'm sure it could be done to a 6.4 cluster. I have 2 6.4 clusters I'd sell cheap if you want to practice on one first.
LittleBlue95
Dec 10, 2022 10:43 AM
Wmyers1
Nov 2, 2021 04:38 PM
helifixer
Apr 7, 2015 07:53 PM
LeneliTanker
Feb 13, 2015 05:34 PM
