Timing question
Old Jul 14, 2024 | 09:19 PM
Dazman63's Avatar
Dazman63
Trailering
Timing question
I‘ve been undoing a lot of work the previous owner did and now I discovered he has the wrong spark plugs in gapped at .039. I ordered new plugs with the correct gap of .044.
I’m also wondering if he installed the distributor the right way. So I timed my 400 to 18 degrees and it seems to run well there. I then cranked the engine over by hand so the rotor lined up with the number one spark plug wire on the distributor. The mark on the harmonic balancer reads 22 degrees.
How can this be? Should it not read 18 degrees?
Old Jul 14, 2024 | 10:24 PM
440 sixpack's Avatar
440 sixpack
You can gap the plugs to whatever you want. the difference between .039 and .044 is meaningless.
4 degrees is hardly noticeable visually don't worry about it. what you really need to do is take a dial back and check your curve. that matters.
Old Jul 15, 2024 | 07:01 PM
jflem's Avatar
jflem
Agreed, you cannot get a timing reading from the rotor to balancer. Timing light required.
Old Jul 15, 2024 | 07:05 PM
Dazman63's Avatar
Dazman63
Trailering
The spark plugs aren’t even listed for the engine and they’re black. I’m used increasing the gap, not decreasing it.
I ordered a dial back timing light, so thanks for the advice on that one as it should make things a lot easier.
Old Jul 15, 2024 | 07:14 PM
Dazman63's Avatar
Dazman63
Trailering
I thought if you installed the distributor with the number one at TDC and ran the engine, shut it off and put it to TDC the rotor would align with #1 spark plug wire. Maybe it doesn’t work that way or I’m missing something. It’s been a while and my current light is very basic.
Old Jul 15, 2024 | 07:22 PM
440 sixpack
You're correct, but slack in the chain and even a little difference in rotor position will cause a few degrees difference. it's not enough to worry about.
Old Jul 15, 2024 | 07:24 PM
Dazman63's Avatar
Dazman63
Trailering
Now that makes sense. Thanks!
I just have to work on the total timing next.
Old Jul 15, 2024 | 07:32 PM
440 sixpack
That's easy. disconnect your vac advance and plug it. set your initial to spec, rev the engine to 2500-3000 and with your dial back see what your mechanical is all in. on a V8 normally 32-38, I assume a 6 is the same. then if it's in the zone hook your vacuum advance back up to ported and see where you are all in.. 45-60 normally depending on the engine and conditions.
If your curve isn't off very much sometimes you can just correct it by changing the initial. if that isn't possible then you work on weights and springs.
Old Jul 17, 2024 | 07:16 PM
Dazman63's Avatar
Dazman63
Trailering
Just removed old plugs.
Old Jul 17, 2024 | 10:06 PM
XSoph's Avatar
XSoph
It wouldn't hurt to take a closer look at the rubber layer on your harmonic balancer if it is original. This layer is known to shrink over time resulting in slippage of the balancer. You can add a new timing label using TDC as a guide, but if it's slipping it should probably be replaced.
Old Jul 18, 2024 | 01:06 PM
Dazman63's Avatar
Dazman63
Trailering
I think so may have to do that. I’m away from work and will be home in 2 weeks so I’m going to check it.
Old Jul 18, 2024 | 04:27 PM
Greaser007's Avatar
Greaser007
You said you had it running pretty good with the 22-degrees showing.
What I would do is time it to your fuel.
Advance your timing in incrememts until it pings on hard acceleration.
Then at that point, back your timing off a smidgen until no pinging is experienced. Done.
Now, you'll be working on dialing-in your idle mixure and speed to your liking, and enjoy.
Hopefully, at this point, the engine will not kick-back against the starter. If so, then retard the timing a sckosh.
Keep us posted.
Old Aug 4, 2024 | 06:30 PM
Dazman63's Avatar
Dazman63
Trailering
I got home on Friday and Saturday I worked on finding TDC. I rotated the engine and when I got on the compression stroke I kept moving the piston until it stopped moving. It lined up on 3 degrees before TDC. I then rotated the engine in the other direction doing the same thing and noted the position on the balancer. The middle point of both marks was 0 degrees before TDC.
So it looks like the 0 degrees is bang on. I also checked the timing and it’s 17 degrees before TDC.
The odd thing is, now I’ve got the correct spark plugs in there is no vacuum at idle on the carb’s port, whereas before I had about 16 Hg. If I give it some gas the vacuum increases. Any idea why this would change?
Old Aug 4, 2024 | 08:02 PM
440 sixpack
That's what ported vacuum should do. nothing at idle and increases as the throttle plates open.
Old Aug 4, 2024 | 08:41 PM
Dazman63's Avatar
Dazman63
Trailering
It’s the timed vacuum port, is this what you’re referring to?
