Sponsored by: Real Truck
Correcting Engine Coolant Ratio
Old Jun 30, 2024 | 05:00 PM
JTVevox's Avatar
JTVevox
Trailering
I did a coolant flush and change on my 2015 6.2 v8 gas and I'm reading just under -20° F with the Prestone tester. 50/50 is -34° F. Total capacity is 20.2 L (5.33 gal) and I was able to drain a full 5 gal bucket from the radiator and engine plugs. I flushed with distilled water, drained 5 gal again, and refilled with my own mix of 50/50 distilled water and Motorcraft yellow concentrate. I tested -20° F so I drained 1/2 gal from the radiator and topped off the degas bottle with concentrate. Took the truck for a drive to let it circulate and I'm still testing -20° F. I ordered another 2 gallons of concentrate, and I plan on draining from the radiator, topping off with concentrate, circulating and then testing. Any guesses on how much coolant I should drain and replace with concentrate to get up to -34° F 50/50 ratio? I measured out 50/50 concentrate and distilled water and the tester measured -34° F on the dot so my tester is accurate.
Old Jun 30, 2024 | 08:28 PM
bajaphile's Avatar
bajaphile
I'm not sure what you mean by - 20F or - 34F...assuming difference on inlet and outlet of radiator? Maybe it's counter intuitive but 100% water would cool the engine much more than 100% coolant / antifreeze. 50/50 is a good ratio to ensure lubrication, anti corrosion and of course anti freezing.
Old Jun 30, 2024 | 08:56 PM
'89F2urd's Avatar
'89F2urd
I think you must be way overthinking this. If you did all that flushing and added 50/50, think no further.
Old Jun 30, 2024 | 09:12 PM
JTVevox's Avatar
JTVevox
Trailering
I'm using this Prestone Antifreeze Tester to check the coolant to distilled water ratio. My ratio right now is more water than coolant because of the water that stayed in the system from flushing. On the tester the ratio is expressed in freeze protection at a certain temperature. A 50/50 mix will provide freeze protection down to -34° F. Mine is reading at -20° F so I'm not at a 50/50 ratio. I was just wondering if someone had experience in this situation and knew about how much I should drain and refill to reach -34° F (50/50 ratio). Yes I'm probably overthinking this, but I want to get my ratio to 50/50 without having to drain, refill, run, and test a bunch of times.
Old Jun 30, 2024 | 10:04 PM
bajaphile's Avatar
bajaphile
Oh Ok I see now... Since you've got 2 gallons of concentrate, just drain 2 gallons from the radiator petcock and fill up with concentrate..
Old Jul 1, 2024 | 01:57 PM
runthatjunk's Avatar
runthatjunk
Well I'm too dumb to figure out the math needed but it's more than 1.5 gallons and less than 2 gallons. I'd just do the 2 gallons and be happy with it.
Old Jul 2, 2024 | 10:49 AM
Mike1's Avatar
Mike1
You're missing a variable here and that's not knowing how much water you left remaining in the engine block, so no one can really give you and answer to your question. My suggestion is the same as the ones above. Drain a gallon out, add a gallon of concentrate. OR drive it as it is for the summer, let some of the water boil / evaporate out and top it off with concentrate in the fall. It's not like it's going to freeze into a block of ice when IF it hits -20ºF Right now at -20 it's good, maybe at -25 it'll start forming some ice crystals maybe at -30 / 35 below it'll start slushing but it'll have to be at least -40 outside to start real icing The coldest my car got in IL this past winter was -24, Your Profile says you live in California, does it get that cold where you're at?
Old Jul 11, 2024 | 05:32 PM
kurthb's Avatar
kurthb
After i flush (since there is just some unmeasurable water left inblock) i just add 3.5 gallons of concentrate (which in my case is 50% capacity) then just finish with distilled water...that way i know i have the correct amount of coolant.
Old Jul 12, 2024 | 08:12 AM
shaun.be's Avatar
shaun.be
Where are you located at? As someone said, water dissipates heat better than antifreeze, if you live in a state that rarely gets below 0 degrees then I would leave it as is, I know my mixture is off in my personal truck, but we rarely get into the teens temperature wise, so I know I'm ok with my coolant ratio.
dunecj2a
Feb 2, 2024 10:44 AM
High_HP
May 18, 2018 01:12 PM
Jolly Roger Joe
Nov 10, 2011 10:09 AM
timferguson
1983 - 2012 Ranger & B-Series
Dec 11, 2006 08:34 AM
abelmoreno
Dec 15, 2005 02:28 AM
