Sponsored by: Real Truck
Question.
Old Jun 16, 2024 | 02:01 AM
Kayden381w's Avatar
Kayden381w
4th Gear
Question.
I'm thinking of getting a 2000 f550. Only issue is it is 2wd. If I were to swap it to a 4wd would I also need to change the rear axle or can I leave the original axle in the back and get a new front one with the same gear ratio? If I don't need to replace the rear axle then do I need to get a front one from the same year as the rear?
Old Jun 16, 2024 | 03:34 PM
apache84's Avatar
apache84
There would be no reason to swap the rear out provided it has the same gear ratio. A 550 is leaf sprung isnt it? IIRC the early SD's 250/350 used a D50 front and the 450/550's SD's used a D60 which is stronger. Might be a bit tough to find a wrecked F550 for parts but who knows.
Old Jun 16, 2024 | 03:36 PM
Kayden381w's Avatar
Kayden381w
4th Gear
I think I know a guy who is selling a wrecked one for like 500 or something like that
Old Jun 18, 2024 | 10:58 AM
shaun.be's Avatar
shaun.be
The last f550 we had at work that was 4x4 which was a 1999 model used a dana 60 leaf sprung front axle, it used regular 8x170 hubs but had the hub adapters to go to the 550 wheel bolt pattern. you will more than likely need to regear the front axle unless you find one from an f550, most had like a 4.88 gear ratio.
good luck.
dcautomotive
Aug 26, 2023 11:02 AM
07Rangernewbie
1983 - 2012 Ranger & B-Series
Jul 28, 2022 10:04 PM
MarkG.
Jan 8, 2022 09:24 AM
bfreehill
Aug 18, 2010 05:10 PM
Kidd
Jul 15, 2001 04:57 AM
