E4oD Core Charge
Old Jun 12, 2024 | 08:49 AM
E350isaBeast's Avatar
E350isaBeast
3rd Gear
E4oD Core Charge
I recently bought a 1993 Ford E350 with the 351 & E4oD. The previous owner provided a receipt showing that a remanufactured transmission was put in.
After driving the van for about 200 miles, I noticed that transmission fluid was dripping from the bottom. After bringing it back to the shop that installed the tranny, I learned that the trans fluid was apparently overfilled, and was being pushed out of the top pressure vent.
The mechanic said this is most likely, but it’s also possible there is a warped piece in the trans that is causing this. The van was driving mint even while leaking.
Thankfully the trans was under warranty and they are shipping a new one out and installing it under warranty (thank God because it was $4,400).
I have two questions:
  1. Is it worth paying the $1200 core charge to keep the old trans?
  2. Do you agree with the mechanics assessment based on the info I’ve provided?
Old Jun 12, 2024 | 09:10 AM
tabijan's Avatar
tabijan
The shop didn’t check fluid level? Did you?
It could be worth $1200 to keep as a spare if the leak isn’t something that needs a teardown to fix.
Sixto
07 E350 5.4 198K miles
Old Jun 12, 2024 | 09:12 AM
E350isaBeast
3rd Gear
The shop checked the fluid after I towed there and said it must have been overfilled because it was sitting at normal levels when hot after the leak (I don't understand this because they are the ones who originally filled it up). I had it towed to the shop after discovered it was leaking because it is under warranty.
There was less than 100 miles on the trans when I bought it.
Old Jun 12, 2024 | 09:33 AM
tabijan's Avatar
tabijan
If it’s at the right level now, can you drive it to see if it still leaks?
Sixto
Old Jun 12, 2024 | 09:47 AM
E350isaBeast
3rd Gear
No because the shop is an hour away and I don't want to void the warranty. I can ask him if he sees it leaking when it's being pulled in/out.
Old Jun 13, 2024 | 07:27 AM
manicmechanic007's Avatar
manicmechanic007
I would not keep the core
Let them fix it under warranty and take your truck away
That fluid expands a bunch when hot
Chances are they just filled it to the full hot mark when it was cold
No big deal, but let them replace the trans (again)
sandymane
Feb 3, 2022 09:09 PM
amockalypsenow
Mar 21, 2017 07:54 AM
msufan
May 23, 2012 12:33 AM
old-rodder
13
Aug 2, 2011 08:36 AM
Pacerguyel2
Jan 18, 2006 04:21 PM
