Sound Deadening Project
- Disconnect batteries (Safety only)
- Remove all seats and center console
- Remove overhead console in front
- Remove the sun visors
- Remove the overhead console in rear (I have the DVD screen)
- Remove all the plastic outlets for a/c
- Disconnect all lights, switches and electricals
- Remove the sun visors and handles on A pillar
- Remove all plastic parts covering A pillar, B pillar, C-Pillar, rear side walls
- Remove the headliner
- Remove carpets front & rear
- Remove all the door panels
- Apply layers starting from the deepest areas under the dash and moving backwards.
- Clean every surface thoroughly with wax & grease remover before applying the base layer
- Apply the 80 mil kilmat layer on floor & roof
- Apply SIless Hybrid MLV layer on floor & roof on top of kilmat
- Apply 80 mil kilmat layer inside the door skins
- Fill B pillar hollow areas with acoustic foam
- Apply Siless Hybrid MLV layer to interior of rear wheel wells
- Apply 80 mil kilmat layer to side walls
- Reinstall in reverse.
I covered the whole floor (because I had the seats & carpet up for another reason), didn't notice any real difference (subjectively of course, no db meter used before & after). While I wasn't expecting Cadillac quite, I thought I'd be able to at least notice the difference.
I (we) will be expecting numerous pictures to ogle while you do all the work!
Get ready to have fun!
I did my entire interior including doors, all 6 inner and outer panels, under the roof above the headliner, and under the hood. In fact I used two layers of 80 mil Killmat. The I added Line-X to the roof for multiple reasons.
I question your decibel values. Most of us before treatment got readings in the 80's. You can see the readings I'm getting in my thread "Sharing my Excursion". It's like riding in a coffin now. I can have a conversation AND hear music at the same time. Take note that just doing one area at a time, you will notice incremental improvements and when you add it up you can expect a huge improvement. Another improvement you can do is silicone body mount bushings. They help with road noise and comfort. Oh, and unless you offload, get some good quiet tires like Michellin's. And don't forget under the hood with a new hood pad, OEM of course. When it's all done, you will be glad you went through the rabbit hole and found the light at the end. I did!
I'm considering doing the inner cowl area with Line-X where the windshield wiper mechanism is. I don't expect much of a change but the net result should show something.
Good luck and keep us posted...
forget about that from a heat stand point.
that hood is heavy enough to lift as it is, put a bunch of Killmat on it, and you will need an Excavator to open the hood.
Looking forward to following your project Prakash, what’s your opinion on those Nitto Duras, mine have been great and super quiet for a big truck tires.
We all want to do it, but from what I've read, the results are mixed. Lots of time, energy and material. One thing for sure... If you're gonna do it, do ALL of it.
https://parts.ford.com/shop/en/us/ot...t-p-bc3z16054b
Yes. The intention is to do the sound deadening all over the interior.
https://www.ford-trucks.com/forums/1...er-needed.html
Not sure why it's showing for Gas models, I'm looking up my VIN. I think they are all the same thought.
We had a huge improvement with a MBRP Quiet Tone 30 resonator.
It was still loud, but tolerable.
However, we had a set of Nitto Terra Grapplers fail on us recently. We replaced with the new BFGoodrich KO3 A/T tires, and this made all the difference. I considered sound dampening, also. But not anymore! I had no idea how much of the noise in the truck was from the tires.
