May be possible stupidity
Old May 15, 2024 | 08:24 PM
440 sixpack's Avatar
440 sixpack
Doesn't have to be timing, but it's likely. things like carbon tracking in the distributor cap or plug wires shorting or bad vacuum leaks can do it also.
What you described will work. you should check it without the vacuum advance hooked up then after setting the timing hook it back up, preferably to ported vacuum.
I'd leave the hold down bolt loose enough you can move it while it's running, if it's still popping try adjusting it a little to see what makes it better or worse.
Old May 16, 2024 | 04:59 PM
jsstephenson2010's Avatar
jsstephenson2010
Trailering
Well thank you to all that responded. I was 100% that the timing was on but that’s what I get for doing my own thinking. It was the timing I was setting it one tooth after ATD. I guess I will pay more attention to the marks I make next time and be a little more accurate and once again THANK YOU TO ALL FOR THE INSIGHT. Many helpful techniques!
Old May 17, 2024 | 06:09 PM
knightfire83's Avatar
knightfire83
Originally Posted by jsstephenson2010
the old stock carburetor wouldn’t hold fuel anymore if it sat for even a day.
Likely ethanol fuel boiling off in the carb.
DaBoss460
Mar 5, 2018 11:01 AM
SC78f150
Feb 20, 2014 02:59 PM
bigblocktrent
Apr 30, 2006 08:19 PM
greybullit
25
Aug 5, 2005 12:45 AM
brennamp
Feb 11, 2004 11:43 PM
