Binding throttle
Old Apr 22, 2024 | 02:35 PM
Junktownbill99's Avatar
Junktownbill99
Binding throttle
Ok, so I know the "throttle stop screw" is there to stop the plates from binding, but this brings me to my issue, if I set it to where unplugged IAC idle is about 500 (where it was recommended) the throttle binds, making it hard to shift, and rpms dont drop well untill i goose it. If I set it to where it doesn't bind, it doesn't idle right, and rpms also don't drop very well.
What if I blocked the holes in the throttle plates? I don't know, its kinda driving me nuts.
Old Apr 22, 2024 | 04:57 PM
AuroraGirl's Avatar
AuroraGirl
check throttle CABLE for routing, original may be bad, and check for the springs on the throttle
Old Apr 22, 2024 | 05:00 PM
Junktownbill99
New cable, everything travels smooth, all springs are there. Will try cleaning this spring though
Old Apr 22, 2024 | 06:16 PM
Conanski's Avatar
Conanski
Somebody may have messed with the throttle plate mounting screws or there is enough wear in the pivot shaft bushings to allow the blades to bind. You could potentially fix both of those issues with the TB removed from the engine, but you might consider just replacing it if you go that far.
Old Apr 22, 2024 | 06:21 PM
Junktownbill99
I didn't realize the plates could be messed with, taking them out would make cleaning the shaft very easy, but I don't want to mess with that for now, (maybe tighten if the screws are loose, I'll check)
Taking the TB off is no issue, Ive done it to replace TPS, and TB gasket, and a new/used is way too expensive.
Is there a bushing kit for these? Id totally consider replacing those.
Old Apr 22, 2024 | 06:37 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The U-pull place I use is $65 with a 90 day warranty. New BBK is junk.
I have never seen a rebuild kit
Old Apr 22, 2024 | 08:47 PM
Conanski's Avatar
Conanski
I removed the plates from one of these throttlebodies one time when cleaning it, it took some patience and fiddling to get them lined up correctly again so I'm pretty sure a mental note was made not to do that again.
Old Apr 23, 2024 | 05:14 AM
AuroraGirl's Avatar
AuroraGirl
If yoiu have not touched your TB, your gasket may have faildd, causing your inconsistent rtesults
Old Apr 23, 2024 | 04:39 PM
Junktownbill99
I Put a new gasket in, old one was toast.
Old Apr 23, 2024 | 05:23 PM
AuroraGirl's Avatar
AuroraGirl
was the throttle body surface true, not corroded , r any other deviance from shiny machined metal? can you use an unlit propane torch around your throttlew with the hose on so you cant get propane to enter the opening with it running UNLES there was a leak? With unlit torch just
Old Apr 23, 2024 | 05:30 PM
Junktownbill99
Yes, it was very smooth and clean, the old gasket was just missing some little pieces, and was smooshed very flat, new one definitely made it run better.
Unfortunately at the moment I don't have a torch that I can use. And I've wasted enough carb cleaner to no avail
Old Apr 24, 2024 | 05:05 AM
manicmechanic007's Avatar
manicmechanic007
I would replace your throttle plate at this point
Old Apr 24, 2024 | 05:28 AM
Soup bean's Avatar
Soup bean
When you put your new throttle cable in, did you orient this sleeve correctly?
The bend in this sleeve should turn toward the passenger's side of the truck, to compensate for the angle of the firewall.
When I replaced my throttle cable, I had the sleeve 180 degrees out, and the cable would bind, causing a hanging high idle.
Green dot is where the cable ferrule would catch on the plastic sleeve.
Old Apr 25, 2024 | 07:39 PM
Junktownbill99
I'll take a look at the cable, to make sure. It seems now as weather warms up, it isn't nearly as bad, and is much more drivable. Thanks for the help everyone.
johnfl
General Automotive Discussion
Nov 5, 2023 09:39 PM
Soup bean
Sep 30, 2023 07:37 PM
john-9
Aug 1, 2021 10:49 AM
rct2000
Apr 29, 2020 07:30 PM
whalerron
Modular V8 (4.6L, 5.4L)
Jul 18, 2006 10:01 AM
