Another 4" pro comp lift question
Old Apr 15, 2024 | 07:55 PM
M70302's Avatar
M70302
2nd Gear
Looking for recommendations for an air bag kit to be used with 4 inch lift pro comp 22415 springs. Also what length u-bolts for rear with these springs? Rear center of axle to fender measures at 27.5 and would like to stay around the same height. Currently have factory springs with aftermarket blocks and half a helper spring that previous owner installed. I do not have the factory jounce to install bags onto.
Old Apr 15, 2024 | 08:15 PM
JSPEX's Avatar
JSPEX
I used the PMF airbag tang plates. They're great. I can't remember what airbags I went with, think it was Firestone. I'll have to look it up. I would also definitely buy the Daystar airbag cradles. I've had much trouble with my airbags staying in place on the bottom so I picked up the cradles, just haven't found the time to install. But I expect them to solve my issue nicely.
Old Apr 15, 2024 | 08:29 PM
JSPEX's Avatar
JSPEX
I just dug up my records - I used the Firestone ride rite kit. And if you are doing the pirate pro comp recipe the rear ubolts I used were 8 inch.
Old Apr 15, 2024 | 09:49 PM
M70302's Avatar
M70302
2nd Gear
Where can I find the pirate pro comp setup or list of parts? I have the 22415 and 22210 leaf springs on order along with shackles and spring hangers. I will get the top plates and cradles as well. I was hoping to find air bags and upper brackets separate but may just have to purchase complete kit. Being a heavy duty mechanic I have all the air line and fittings readily available.
Old Apr 16, 2024 | 08:22 AM
mcquojo's Avatar
mcquojo
Trailering
Below are the parts I used. I just did this lift in March.
Front ubolts should be 9.5 length. I ordered 8.5 the first go around and they were too short. The rear ubolts are plenty long enough.
I used different shocks as well, but included the list for bilstein.
You can also find a cheaper adjustable track bar. I think most guys use on from Zone
Procomp front 22210 x2
Procomp rear 22415 x2
PMF-UBFSR563-30-095 Front Axle Ubolts
Bend Type: Semi Round
Leg Length (C): 9.5"
1 kit
PMF-UBR625-SRW-0 Ford 1999-2010 F-250/350 Ubolts
Ubolt Diameter: 5/8"
Axle Diameter: SRW
Block Height: None
Leaf Pack Type: Without Top Overload Leafs
1 Kit
PMF-FRD-4050-AT-625 Airbag Tang Ubolt Top Plates rear
Configuration: 5/8" Ubolts (stock)
1 set
PMF-FRD-5012 1999.5-2004 F-250/350, Excursion Monster Adjustable Trackbar
Qty: 1
WFO 2 degree shim
2 Degree Steel Axle Shim, 3" Wide
SKU: WFO 2.0-3
Quantity: 4
Rear Bump Stop (energy suspension)
  • 9.9155
  • Product Name: Rear Axle Bump Stops
  • Quantity: 1 set
Front Bump Stop (energy suspension)
Product ID: 4.9103
Product name: Front Axle Bump Stop 2”
Quantity: 1 set
Front shock Bilstein
33185545 front
Rear Shock Bilstein
33236964 rear
Old Apr 16, 2024 | 10:22 AM
unleashd's Avatar
unleashd
I have this cheat sheet...Haven't made up my mind on which way to go
Old Apr 16, 2024 | 10:52 AM
Antonm23's Avatar
Antonm23
Neat spreadsheet, but do you not think you'll need u-bolts and shims for the X/C code spring swap too?
You have those part costs factored into the procomp lift, but not the code spring lift. Also the "rolling chassis" note at the bottom, just FYI model year 2008 is way different from the 05-07 truck front setup.
Old Apr 17, 2024 | 05:33 AM
unleashd's Avatar
unleashd
ATS includes U-Bolts, Shackles etc. in the price of that kit. Good pointer on the rolling chassis. I'll update it.
Old Apr 19, 2024 | 10:10 PM
bajaphile's Avatar
bajaphile
Firestone ride rites work great - I am running the same rear springs. I got some Daystar cradles which adds about an inch to the overall assembly. They allow the axle to droop a bit and most importantly don't stretch the bags which may cause damage. The bags themselves are most likely designed for the stretch, so I wouldn't consider them being required...
MasterX
Apr 20, 2021 01:42 PM
Blakshukvw
Nov 4, 2016 11:29 AM
Rscottc
May 14, 2015 06:19 AM
rockcrawler_101
Nov 10, 2011 07:31 PM
mtgrzlyman
May 19, 2005 02:35 PM
