Sponsored by: Real Truck
Alarm randomly going off
Old Mar 22, 2024 | 01:55 PM
EScott's Avatar
EScott
4wd High
hi everyone,
I have a 2013 F550 work truck which is set up as a 16' flatbed. Recently, the alarm has been randomly going off. I have read these threads about bugs flying around inside the cab and motion sensors within the truck. This is a work truck that we've owned since 2013. I have never had these issues before and doubt that there are motion sensors inside of the cab. And I've seen comments about loud noises and vibrations setting off the alarm. That has never happened before either. I watched one video on youtube and thought that it was the hood latch. After buying a new hood latch, I then realized that the video I watched was for a 2011 F250. That truck had an electrical connection on the latch. Mine does not. Someone else had also mentioned that it could be the battery in the key fob. I changed that too and the alarm is still randomly going off. I'm going to check for those motion sensors on the rear view mirror and if they are there, I can just put some tape over them??
Does anyone have any other ideas? I got so annoyed that I took the 20Amp fuse out for the horn. That should not be a permanent fix!
Thanks
Scott
Old Mar 23, 2024 | 10:12 AM
5851a's Avatar
5851a
The door latch switch might need cleaning or replacement.
Old Mar 27, 2024 | 07:04 PM
Wfduggan's Avatar
Wfduggan
Trailering
Could be the antitheft ecm starting to go bad too. Mine did it right before it stopped operating the electric locks. It still goes off on occasion typically in cold weather. 50 and below.
racehead2
May 16, 2023 03:47 PM
blain stumpf
Nov 16, 2022 06:24 PM
mattymax
Oct 30, 2022 06:40 PM
bhenders
Electrical Systems/Wiring
Apr 2, 2020 03:00 PM
Mack3006
Oct 30, 2018 01:09 PM
