Need Help, multiple module failure
Old Mar 16, 2024 | 10:07 AM
RJCRD's Avatar
RJCRD
7th Gear
Hey Everyone,
I have been battling with an electrical issue in my 2017 Super Duty Platinum Diesel. Been out of service for over 2 months now, has been to multiple mechanics including Ford dealerships and everyone is at a loss to pinpoint the problem.
Every module on the safety network randomly failures and loses communication with the Gateway module. I am on my 3rd gateway module in 3 weeks right now obviously that is not the issue. Will work for about 50 miles sometimes more sometimes less the wrench comes on with the ABS, hill decent, 4X4, adaptive steering, front cam, navigation, tractions control nothing on the tree works, airbags and more 11 total modules. Now the funny thing is not all of them always fail all the time. Sometime just the ABS and Navigation, sometime is it just the hill decent and traction control. Sometimes they all fail. We have checked all the connectors at the back of the truck and all of the recalls have been done. Sometimes when I restart the truck they all go off and it is ok for a little while sometimes they stay on.
I need some help please
I have attached a video of all the faults
Thanks in advance
RJ
File Type: mov
Old Mar 16, 2024 | 11:15 AM
bilder's Avatar
bilder
You might look at the pins and sockets in the plug connectors, being pushed in and not locked in place
Old Mar 16, 2024 | 12:15 PM
aquanaut20's Avatar
aquanaut20
What codes do you have and have you connected a scope to the comms circuit ?
You most likely have a corroded wire or terminal (green crusties)
Old Mar 16, 2024 | 12:21 PM
RJCRD's Avatar
RJCRD
7th Gear
I dont have the codes in front of me, I have to talk to the shop on Monday. they have checked every single pin at every connector on the whole network and all the wires seem in tack and operations as they should. I am thinking it is a alternator or battery. I have a monitor hooked up and running it now watching voltage. right now its at 14.7/.8 and all lights are issues are NOT present and everything is working fine.
Old Mar 16, 2024 | 01:18 PM
Dented's Avatar
Dented
I've been having a similar problem on my 23 7.3L.
It's sitting in the shop while they try to figure out WTF is wrong with it. Going to be intriguing to follow this.
Old Mar 16, 2024 | 01:44 PM
number9xd's Avatar
number9xd
Did water get into the under hood fuse box? I’ve read accounts of that causing electrical issues
Old Mar 16, 2024 | 01:55 PM
Alpinweiss's Avatar
Alpinweiss
I had similar issues and the reason was water intrusion into the main module in passenger foot well. Many contacts were in really bad shape. Three pins were corroded broken and had to be resoldered.
Your symptoms are definitely connection related. Pull all connectors and check them thoroughly.
The connectors in these new trucks are ridiculously small for cost reasons that they truly are a pain in the rear department
Old Mar 16, 2024 | 03:33 PM
RJCRD's Avatar
RJCRD
7th Gear
Nope pulled the entire inside of the truck apart and out of the cab and 0 water damage... checked under the hood NOTHING no water...
Old Mar 16, 2024 | 09:42 PM
Louisville Joe's Avatar
Louisville Joe
Sounds like a bad connection in the bus if battery voltage is stable. If it's a bus problem, it could be anywhere along that circuit. They replaced 3 gateway modules?
Old Mar 16, 2024 | 10:33 PM
mwheue's Avatar
mwheue
Check the plugs just above your e brake also for a good connection.
Old Mar 17, 2024 | 08:38 AM
RJCRD's Avatar
RJCRD
7th Gear
Currently I am on the 3rd gateway module in 3 weeks... I told the dealership it was not the issue BUT they insisted it was the issue and of-course it is NOT. I just had the brakes and hubs, done along with the ebrake a couple week before this all started happening so I will deff check that!
Thanks
Old Mar 17, 2024 | 10:17 AM
speakerfritz's Avatar
speakerfritz
Ive had those alerts all at the same time
at first I thought it was the big connector by the spare tire....cleaned it then dielectric greased it...but still had the alerts.
then I realized that the alerts started after I fluid filmed everything.....so I presure washered all the connectors and sensors (abs ) with a wide pressure nozzle.
problem solved
apparently the fluid film changes the capacitance of the cables around the abs sensors and then everything that uses the abs sensors goes hay wire.
Old Mar 18, 2024 | 06:23 PM
RJCRD's Avatar
RJCRD
7th Gear
interesting, I will deff check that out... I did the same went right to the connecters in the back but they were dry as a bone. I did just have the hubs, a speed sensor and brakes done a month before this all started happening.
Old Mar 19, 2024 | 01:26 AM
speakerfritz
that speed sensor would be my prime suspect.
Old Mar 20, 2024 | 09:54 PM
RJCRD's Avatar
RJCRD
7th Gear
that has been check multiple times, not the issue from what they are telling me...
