7.3 injector cups
Old Feb 27, 2024 | 08:02 PM
Edwardba's Avatar
Edwardba
Trailering
7.3 injector cups
I’ve got a 2002 f450 with cracked injector cups only symptoms I had was white smoke for a minute or 2 after starting and diesel in coolant. Are there any other symptoms anyone else has experienced im going to replace the cups soon .As of recently it’s harder to turn on if it does turn on it shuts off .im trying to find out if anyone has had the same symptoms to find out if the issues are related or if I have a different issue to fix .in my opinion sounds like the cracks have gotten bigger and is somehow causing a misfire until shutoff.
Old Feb 28, 2024 | 03:20 AM
udsuth78's Avatar
udsuth78
What your fuel pressure during all of this? Check the tech section up in the stickies for an easy test method. Has the engine ever acted hydro locked when trying to start? I'm not sure I'd run the truck in it's current condition. If a crack progresses to the point of allowing coolant or fuel into a cylinder, that is a recipe for a bent rod and/or crankshaft.
Old Mar 1, 2024 | 08:07 PM
Picky1962's Avatar
Picky1962
I didn't have any issues when the dealership found diesel in the coolant while it was in for a non-engine issue.
Sledjunkie
26
Dec 30, 2020 07:39 AM
Jjohn7.3
Jun 19, 2018 10:24 PM
Leemakesmepee
45
Apr 5, 2014 05:56 PM
coryv4
Sep 11, 2013 09:51 AM
Kdr358
32
May 26, 2013 12:43 PM
