Sponsored by: Real Truck
Correct transmission fluid
Old Feb 24, 2024 | 09:53 AM
westbrook12345's Avatar
westbrook12345
1st Gear
2000 Ford F-450 Super Duty
10 Cyl 6.8L; 5-Speed Manual Transmission
Read several articles on which is the correct transmission fluid to use. Owners manual & transmission sticker states Mercon syn and now since mercon has changed to mercon V to use that. A local mechanic said to use any full syn and if the trans chatters to use mobile 1 LV. All the reading Ive seen states to use only motocraft mercon V. What do I use? I do have some dextrose III/mercon in my shop thats available. Looking for some advice. Thanks
Old Feb 24, 2024 | 06:00 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. An old adage that applies here: "When in doubt, read the book". I would go with what your manual says to use. It is probably what has been in there since new anyway!
Old Feb 24, 2024 | 11:01 PM
Fomoko1's Avatar
Fomoko1
Moved to this forum.
Old Feb 25, 2024 | 01:49 PM
redford's Avatar
redford
FTE Leadership Emeritus
Mercon LV replaced all applications requiring Mercon SP, not Mercon V. I wouldn't use LV ( Low Viscosity) in any application that doesn't specifically call for a low viscosity fluid.
Mercon V is still available from many different vendors.
Old Feb 25, 2024 | 03:41 PM
Arktisk's Avatar
Arktisk
4wd Low
A lot of folks run this Mobil 1 ATF in both trans and xfer.
tseekins
23
Jun 9, 2013 08:17 PM
BLK94F150
May 27, 2008 08:58 PM
jake00
Mar 26, 2006 07:50 PM
treb
Jul 29, 2003 11:59 AM
Pastmaster
Jan 30, 2002 10:26 PM
