SPEEDO DRIVE
Old Feb 13, 2024 | 03:55 PM
Rad082625's Avatar
Rad082625
SPEEDO DRIVE
just swapped the trannys in my 67 CS. Out went the FXM,COM? whatever it came with and replaced it with a C6 out of a truck with the bolt on yoke to mate up with my 2 piece driveshaft .The problem is it came without a speedo drive and I'm playing hell trying to find the right type. Any ideas?........Bob
Old Feb 14, 2024 | 12:33 AM
Green72F250's Avatar
Green72F250
Not sure if this is what you are looking for, but it has some good infomation. Scroll down till you find the FORD section
TCI Auto Speedometer Gear Calculator - TCI® Auto
FORD SPEEDOMETER GEAR INFORMATION
Ford Speedometer Gears
6 teeth - machined into output shaft (C6 only)
- Ford drive gears are machined into the output shaft on C3/C4/C5/C6 & AOD transmissions. You may need to remove your tailhousing to determine how many drive teeth your transmission has.
Old Feb 14, 2024 | 07:13 AM
Rad082625's Avatar
Rad082625
Thanks but I'm looking for the entire speedo drive unit; I'll worry about what gear inside the unit later.
Old Feb 14, 2024 | 11:20 AM
52 Merc's Avatar
52 Merc
Do you mean you need a speedometer cable? What drives the speedometer, the drive gear, would be inside the transmission, as described above. The cable holds the driven gear on the end, which fits into the transmission.
Old Feb 14, 2024 | 12:06 PM
Rad082625's Avatar
Rad082625
I need the part that is between the speedo cable which is outside the tranny and holds the speedo gear that mates to the drive teeth that are cut into the output shaft that is inside the tranny and connected to the bolt on yoke that came on F250 trucks with the two piece driveshafts. I've looked for any drawings that show this part but cannot find any....Bob
Old Feb 14, 2024 | 01:23 PM
Green72F250
Does this look like your C6 transmission set up?
Old Feb 14, 2024 | 01:53 PM
Rad082625's Avatar
Rad082625
Yes. 17322 is speedo driven gear and 17269 is speedo bearing or sleeve maybe but when I go to find 17322 driven gear there are many variations on the web but none say for a C6; there are listings for manual trans like t-18 or t-19 but none I found for a C6. Plus 17269 looks to thread into housing where mine uses a V shaped clamp with a bolt....Bob
Old Feb 16, 2024 | 01:58 AM
RTT's Avatar
RTT
JUNKYARD
Old Feb 17, 2024 | 08:51 AM
Rad082625's Avatar
Rad082625
No kidding.
Old Feb 17, 2024 | 05:24 PM
DirtyFerd's Avatar
DirtyFerd
Is this what you're looking for?
https://www.cjponyparts.com/cj-class...4aAlUOEALw_wcB
Old Feb 17, 2024 | 09:53 PM
Rad082625's Avatar
Rad082625
No, like I said complete speedo unit
Old Feb 18, 2024 | 08:10 PM
DirtyFerd's Avatar
DirtyFerd
How about this?
https://www.moderndriveline.com/shop...le-slip-in-90/
Old Feb 18, 2024 | 09:23 PM
Rad082625's Avatar
Rad082625
No but thanks anyway. Wrong type end for my speedo head which is screw on type.
Old Feb 24, 2024 | 02:47 PM
RTT's Avatar
RTT
Red face Strange
This should NOT be this difficult
Restoring beaters is the BOMB & venders parts are flying off their shelves !!!!!!!!!! C6's parts r everywhere ,
I would get all the numbers I could find off the C6 , find out the year it was made . Call or google and find the part or a vender that sells them
Myself actually have a speedometer cable problem . I found a universal cable that is much less than a FORD
, plus I need a longer one because I have long tube headers .........
Rad082625
Sep 4, 2023 10:39 PM
Nodz
Oct 18, 2022 02:42 AM
AndysFords
Jul 20, 2006 09:33 PM
wment
Feb 11, 2006 09:39 PM
Frdbuy8589
Aug 25, 2003 07:24 PM
