does a 460 motor fit in a 88 150
Ford put the 460 (7.5L) into the pickup body, so you can buy all the stock parts to drop it in. You may have to hunt junkyards for a while, but it can be done with factory parts and no cutting.
The 7.5L has the same bellhousing as the diesels, so look for a transmission from a diesel truck.
Steve is right, the bodys are the same from the F150 clear up the F450 superduty. The only diff is the springs. You will most likely need heavier front springs to accomodate the extra weight of the 460, if you're goin EFI I would look for an f250 or f350 that is around the same year as the truck you are wanting to put the 460 in it will be easier to buy a complete donor truck than making a million trips to the junkyards..
Ben88f150
Is your truck a two wheel drive or a 4x4?
These are the factory mounts that you will need, regardless.
http://cgi.ebay.com/ebaymotors/ws/eB...ory=33613&rd=1
RGAZ
05-15-2001 01:56 AM
