Differential Break In Procedure
Old Jan 16, 2024 | 12:21 PM
Legend187X's Avatar
Legend187X
4wd Low
I ordered a set of 5.13 gears for my excursion and have been reviewing the recommended break in procedure by Nitro Gears. They recommend 10 miles of driving, 20 minutes of cool down, and repeat this process 5 times. After this, light driving for 500 miles.
My question is, should I have the vehicle in 4wd during this to break in the front diff as well? I just have concerns running in 4wd on dry pavement
Old Jan 16, 2024 | 01:33 PM
Beechkid's Avatar
Beechkid
If you have traction lock diff's then I would only engage the RWD side and then look for a "soft" are to break-in the front. If that's not possible, you are going to be driving slow anyway so as long as you are not making sharp turns you should be ok. I'm sure if you check with NG they will say the same thing.
Old Jan 17, 2024 | 08:52 AM
1Butcher's Avatar
1Butcher
I suspect you will get all kinds of ideas to break things in. I know, all new cars do not have break in procedure. Make the car, Sell the car, Drive the car.
When I rebuilt mine, [Sterling 10.25] I swapped just about everything and drove it for a week or so. Took off the cover, drained the oil, and installed a Banks cover. Topped up with synthetic oil. Drove it for the summer towing my 5th wheel. No problems what so ever.
That was my procedure.
Old Jan 21, 2024 | 07:10 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Butcher, it is not the same to compare a rebuilt diff & one that comes in a new vehicle.
The tolerances used & precision equipment used at the factory is far superior to what is used in a shop.
Some brands load test all drivetrain components before they get installed.
Old Jan 21, 2024 | 08:43 PM
1Butcher's Avatar
1Butcher
We just have a different opinion I guess. With the right builder, I bet that someone that is passionate with what they do is way better than a robot or even a person that has no clue where the part is going.
With today's oils/technology/materials, break in is a thing of the past.
I used to work at a German car dealership where we changed the engine oil/filter every 3,750 miles. When that manufacture elected to go for extended oil services and 2 years/10k miles, I laughed and knew were were going to be busy with engine work for some time. That time never occurred. No matter what I thought, longer services did work and engines never had abnormal wear. Matter of fact, they needed less repairs. I would have lost a lot of money if I bet the engineers were wrong.
Sometimes, old thinking should be put to rest.
Old Jan 26, 2024 | 12:57 PM
Crop Duster's Avatar
Crop Duster
Totally agree. The last rear I got was a 3:73 trac loc, the instructions said find an empty parking lot do 5 or 6 figure 8's then drive it like you stole it. That was 6 years ago, and it is still perfect. If anyone told me I had to jump thru all those hoops to break in their stuff, I would be looking for someone else to do business with.
Old Jan 27, 2024 | 10:26 AM
1Butcher's Avatar
1Butcher
In life, research, research, research. Make a decision and be happy that you made a good decision that makes you feel happy.
Old Jan 27, 2024 | 05:52 PM
Beechkid's Avatar
Beechkid
Hoopers in Sun Valley California has been around for 40 years, family owned and does nothing but diff's..... this is where EVERY dealer in the Los Angeles area sends vehicles to....... they use to run their own sprint cars back in the day.......they still insist on "Break-in procedures".
MB Classics
May 17, 2011 02:16 PM
USAF FordGuy
1978 - 1996 Big Bronco
Nov 9, 2009 03:08 PM
CJ_Canales1
Jan 30, 2004 07:27 AM
patches
Jul 29, 2003 06:15 PM
