B II low pressure cutoff switch location
Can someone tell me where this switch is exactly located because I could not find it.
I looked at the right side of the front where it should be bud I did not find any switch.
Bronco II 1988, 2.9L
(There's a cannister located on the right side of the engine 9compartment, that's the acumulator. There is an electrical connector on the low pressure cutoff switch. Remove the connector and jumper it with a wire. The compressor clutch should work now, but you probably have a leak and the freon is gone. You need to properly recharge the system and locate the leak. An automotive AC shop has 'sniffers' or dyes that will find the leak.
Regards, Ray
Regards, Ray
Fixnstuff
09-26-2016 09:56 PM
Lngbeard
15
04-29-2016 11:24 AM
dbrydon
01-05-2016 02:37 AM
