The official pulling it out thread
Last week my KC bellowed up-pipes, Big Iron Oil pan, and other misc goodies came from riffraff. I somehow managed to get this entire week off, so what better time than to get it out and get it on a stand. I'll take some more pics tomorrow of the parts, and progess. Got the header panel and some misc stuff out of the way in about an hour tonight just tinkering around in the garage. Im shy a few clean buckets and all my used oil containers are full, so ill get that squared away first thing tomorrow, and hopefully have it out tomorrow night, or ready to come out friday. Pulling the entire front clip off, because now that I have the time, this may turn into alot more than just an engine re-sealy-do. Planning on new oil pan, new rear main, new up-pipes, oil cooler re-seal, injector o-rings and probably glowplugs, as well as replacing any seals or gaskets I havent done yet (banjo bolts, oil galley plugs etc.). As long as nothing crazy happens during this, Im doing the saginaw powersteering pump conversion, all new p/s - booster - gear box hoses, and a new steering box (yet to be determined if im going newer generation ford box, or blue top).
Good old rust. There should be another piece in there where the bottom corner of the header bolts in. both sides were the same.
Fog lights that had zero wiring running to them, probably just removing them entirely.
Someone didnt like to use OEM replacements. These will definitely be getting swapped as all of the shiny-ness on the inside is peeling off.
Oil pan seems to be really good quality, im not so sure what how much of an impact reinforcing the lip is going to have, but overall for the cost of an OEM pan, or even a $100 spectra and the 80$ weld in flange, the $240 price tag didnt seem too bad.
making stock 6.7 power stroke numbers on an engine I can work on without pulling the cab is a huge benefit. would help towing 15k pounds with the old girl also.
sorry didn't mean to hijack your thread, keep the pictures and progress coming, i like things like this.
I think im going to have to evacuate the AC system. Not that I want to or need to, but im almost positive the evaporator is leaking something fierce. When im under the truck tomorrow, ill snap some pics. I know NOTHING about AC systems, so dont know if this is a job I can tackle or if I need to take it somewhere. Ill research into this further.
Has anyone done the GPR-relocation mod? Since I have the AIH deleted, Id like to get rid of that relay and relocate the GP relay over to the fender, just not sure if the juice is worth the squeeze on that one. Would really help clean up on top of the motor there.
The last two pictures I have a question about. Theres a hot power wire running from the pass side positive cable/terminal, that goes up to the GP/AIH relay, are all the superduties like this or is this something someone "fixed"? Also, I forgot to take some pics, ill do my best to remember in the morning, but the inside of these coolant lines (top and bottom) was very interesting, almost like a sediment, not 100% sure what it is, but a coolant filtration system is in my future for sure. Enjoy the pics, hope to have it out of the beast tomorrow.
Intercooler looks pretty good.
Radiator is brand spankin new.
Small chip in the fan blade.
Going to need alot of these. The old ones like to just "snap"
Cant find my old fuel line tool, hope I can make these work. If not, well they were like $10.
So this was probably the most nerve wracking part. As most of you have seen on previous threads, the 42pin connector bolt was "stripped", as in the piece the nut is held into by was broken, thus allowing the bolt to just spin freely without backing out. I'm basically a surgeon now.
Little protector I made in case I had any slips.
Turns out cutting the head off the bolt would be the easiest part.
I had to kind of work around where the plastic meet the bolt with a very fine tipped screw driver, and got the little o-ring popped out, after that I had to use an uncomfortable amount of force, but BOOM SUCCESSSSSSSSSSSS.
It was a very very tight squeeze to get the dremel/cut off in there, and at the right angle, but it CAN BE DONE!
This power steering pump is DEFINITELY NOT going back in, looks like it was leaking from every orifice.
NASTY
Turbine wheel has some wear, but ZERO play. I doubt this is the original turbo, ill try and snap some pics of the tags on it.
That hose fought me like its life depended on it.
Potentially a manifold leak? Couldnt really tell from the angle, going to investigate this further for sure.
Power lead off pass positive lead.
Runs up to gpr/aih relay, is this normal?
Where progress ended for the day. Just gotta spend the morning on the creeper, and shell be ready to exit
The new ride, best pic I have on the phone, sorry. 2007 Wrangler X.
you'll be surprised how well made the factory turbo is, have taken apart some with over 400k miles and they had no play, only reason for the rebuilds was to either "I'm already there" or to upgrade the thrust bearing to a 360° one and add billet wheels or just replace the factory surge prone ones.
Looking good looking forward to more pics
I move the gpr relay the the passenger fender on mine. Cleaned valley up a lot and got more room for activities in there.
I did end up evacuating the AC system, as I think ill be buying a new condenser mine is pretty beat up from rocks, and looks like its almost compromised in some spots. Along with fixing the leaking part that I dont know the name of (the compressor lines run into it, almost like a pressure tank?. Ill take a pic of it and throw it up later.
Had to go buy some new ratchet wrenches (they dont like cheater bars, and they had been broken prior to this), was like sweet this will make the motor mounts super quick. Well stupid me, first bolt on the front, I ran too far down, ratchet wrench stuck for life (until I got the rest of the bolts out)
.Going to run to the store this morning and get some bolts that match the bellhousing and get this baby on the stand and ready for some serious cleaning.
Im hoping I can just throw this baby in neutral and push it to the back of the garage, then ill have room to get the jeep inside as well!
I forgot how much a mess this makes.
THERES ALWAYS ONE!
Using a ratchet strap on the front, will get you the perfect angle for the up pipe collector to clear everything, and get the oil pan over the top cross member.
Temporary resting place for the night.
I always do this. For whatever reason this is the one mistake I never learn from. I always forget about the ratchet strap.
