Treasure found
Old Nov 14, 2023 | 10:54 AM
CJMOStang's Avatar
CJMOStang
Treasure found
I was putting new dovetail striker on my 49 F1 last night and dropped the new nut behind the door
frame. When I pulled the last pice of interior trim, I found this paper. It is a full paper rolled up with a December 1948 Ford Chicago insert. It’s in pretty bad shape, but it had to be left there on the assembly line I guess. Does anyone know the history of a Ford paper?
Old Nov 14, 2023 | 02:37 PM
DieselDog409's Avatar
DieselDog409
that has to be worth a boatload of cash to the right ford whizz
Old Nov 14, 2023 | 07:37 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
What is the serial number of your truck? The database folks here can probably figure out exactly when somebody was reading that paper. As to when the mouse chewed it up for bedding.....anyone's guess.
Old Nov 14, 2023 | 11:31 PM
CJMOStang's Avatar
CJMOStang
My last 6 are 172688 if part of that is the number. Is there an online decoder somewhere. I would love to know more about my truck originally.
Old Nov 15, 2023 | 06:41 AM
Greg Rogers's Avatar
Greg Rogers
How cool. Can you open it up and post pics? That would be interesting reading!
Old Nov 15, 2023 | 08:27 AM
CJMOStang's Avatar
CJMOStang
It is very fragile and I’m afraid to open it too much because it wants to fall apart.
Old Nov 15, 2023 | 10:41 AM
52 Merc's Avatar
52 Merc
That is very cool and amazing someone on the assembly line would stick a time capsule in the corner like that. That's an even better score than the original registration and insurance cards I found that blew out of my header panel above the windshield the original owner stuffed in.
As for online decoder, it's right here. In addition to the serial number, there should be a series of numbers and letters hand stamped into the firewall, near the cowl seam. That is your production code that will identify the color code, assembly plant and build date. If you can find that and post it here, clear pictures are best, we can share those details about your truck. It may look something like this...
Old Nov 15, 2023 | 07:03 PM
CJMOStang's Avatar
CJMOStang
I don’t see anything there. Could it be somewhere else on a ‘49?
Old Nov 16, 2023 | 09:13 AM
ternus's Avatar
ternus
my '49 has it, same location
Old Nov 16, 2023 | 07:38 PM
52 Merc's Avatar
52 Merc
Upper center cowl/firewall is probably the most common spot to find the stamping. They are sometimes found on the firewall near the main wiring pass through seal, or more central on the firewall. We've also seen them close to the patent plate. It's also possible, from the look of your picture, that a PO did some body work there and smoothed the area before painting. Your numbers may be there under a quarter inch of bondo.
Frank79
Mar 2, 2022 07:29 PM
pearljam724
Jan 29, 2022 10:09 PM
Another rusty Ford
Mar 17, 2020 06:50 PM
jeepcj559
13
Sep 24, 2019 01:39 PM
cje07
1978 - 1996 Big Bronco
Sep 7, 2008 07:42 AM
