A great technical description follows...
Old Nov 23, 2003 | 02:11 AM
ZombieSlayer's Avatar
ZombieSlayer
The only things forward of the cab at this point are; motor (maybe a 352 that was rebuilt), inner fenders, and the radiator support.
I have inspected the rad support and it's resuable, not perfect, but not a rusting heap either I have removed it a couple of times already trying to get the front end put back together.
Guess I'll just chisel the "pucks" and install the new ones
Thanks for the info guys~n~gals This place absolutely rocks!
Old Nov 23, 2003 | 09:23 PM
FordBoypete's Avatar
FordBoypete
Thumbs up More stuff
ZombieSlayer,
If you want to eliminate the rusty bolts for next time, this time when you put insulators back in there, use stainless Bolts, Nuts & washers, plus slather everything that's a metal fastener with a good dielectric compound.
Also it helps to refinish your metal parts, where the insulators actually sit & contact it, using an epoxy paint. Even a rattle can of semi gloss black epoxy is better than other finishes.
FBp
Old Nov 24, 2003 | 02:16 AM
ZombieSlayer
FBP I've already purchased stainless steel hardware I'm just not having luck getting these things off.
Old Dec 1, 2003 | 11:31 AM
William's Avatar
William
Use a block of wood and a bottle jack to raise the core support up about 1/4 inch. Hit the puck with a BFH, it will come out, sometimes quickly!
Old Dec 1, 2003 | 09:24 PM
ZombieSlayer
I haven't gotten to this yet, I'm having trouble getting the $$ for the "pucks". I will find out Wed as to when I get to start work Ford wants $25 for each piece (4 pieces needed 2 on each side)
DaytonaTunnel
Aug 18, 2014 10:28 PM
awillo0406
Apr 18, 2013 03:00 AM
Greywolf
30
Jul 5, 2011 10:11 AM
fisheasy
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 18, 2009 12:15 PM
glruff
Delaware Chapter
38
Aug 10, 2007 09:39 PM
