1978 - 1996 Big Bronco
factory tach
Old Nov 21, 2003 | 01:28 PM
muscletruck7379's Avatar
muscletruck7379
factory tach
how is the factory tach hooked up? mine is somehow unhooked(most likely at the engine) and I would like to get it going again, but the only wire that I dont have going anywhere is a red one(it ran w/this wire unhooked)any ideas?
Old Nov 23, 2003 | 12:08 PM
steve83's Avatar
steve83
What year? What engine? What instrument cluster? What trim level (Custom, XL, XLT, EB)?
Old Nov 23, 2003 | 06:40 PM
muscletruck7379
84, 302, xlt
Old Nov 23, 2003 | 09:44 PM
steve83's Avatar
steve83
It gets its signal straight from the coil on the DG/Y wire, power thru fuse 18 on the R/Y wire, and grounds thru the Bk/DG wire in the small (4-pin) connector. Check the fuse.
Old Nov 23, 2003 | 10:33 PM
muscletruck7379
ok, will do, thanks
Old Nov 30, 2003 | 01:20 PM
stinkystank's Avatar
stinkystank
I've got a similar problem with my '81 Bronco stock tach, only it comes and goes whenever it pleases. There's a short somewhere but where do I start looking?
Old Nov 30, 2003 | 06:10 PM
grogant's Avatar
grogant
yeap hooks up off the coil. mine was acting flakey all over the
place. Took a wire brush attachment on my dremel tool and
cleaned the terminals on the connector and the coil then sprayed
some electrical sealant on it and it has preformed flawlessy ever
since.
Tim
Old Dec 1, 2003 | 07:38 PM
muscletruck7379
come to find out all mine was, was a disconnected power wire!
