kats28911
Old Oct 5, 2023 | 11:57 AM
kats28911's Avatar
kats28911
5th Gear
kats28911
Have a 1985 F-250 with a 460 and 4 speed having problems with it not wanting to go over 25mph any thoughts?
Old Oct 5, 2023 | 12:22 PM
BigBlue2's Avatar
BigBlue2
If the engine starts and idles normally but can't build RPM you could have a fuel supply issue. Replace any fuel filters. Check your fuel pump pressure and flow. If timing and fuel check out you could have a plugged exhaust.
Old Oct 5, 2023 | 01:21 PM
kenny nunez's Avatar
kenny nunez
25 mph 460
Another possible could be a plugged up exhaust system.
Old Oct 5, 2023 | 02:04 PM
kats28911's Avatar
kats28911
5th Gear
Thanks yes it idles ok and the exhaust sounds great Have replaced the fuel pump on rear tank cant find any other leaks
Old Oct 5, 2023 | 03:03 PM
kr98664's Avatar
kr98664
What are the symptoms? Does the engine chug? Or just bog down? What happens at the same RPM in 3rd gear?
Old Oct 5, 2023 | 03:11 PM
FuzzFace2's Avatar
FuzzFace2
I am for a plugged exh.
If running a cat it could vary well be plugged at this time.
Also dont over look a bad muffler.
The baffles may have come loose and is plugging the path for the gasses to get out.
When cold take a rubber or dead blow hammer and hit the bottom of the muffler.
If you hear it rattle this it could be bad.
If you use a vacuum gauge on the motor what dose it read at idle and at higher RPM?
Same with a load on the motor what dose it read?
Or you could drop the exh before the cat and go for a test drive.
Dave ----
Old Oct 5, 2023 | 03:13 PM
BigBlue2's Avatar
BigBlue2
Yes, and what is the history of the issue? All of a sudden or worse over time?
Old Oct 5, 2023 | 03:16 PM
85e150's Avatar
85e150
Vacuum leaks at manifold/head junction.
Old Oct 5, 2023 | 03:18 PM
BigBlue2's Avatar
BigBlue2
A plugged exhaust limited situation the exhaust sounds good up to the point of too much back pressure. Happens pretty consistently at the same RPM and load.
Old Oct 5, 2023 | 04:22 PM
kr98664's Avatar
kr98664
I am for a plugged exh…
Well, I am firmly against it. Not sure why you would wish that on anybody…
Old Oct 5, 2023 | 06:00 PM
351Cleveland C4's Avatar
351Cleveland C4
Are the brakes dragging?
I can't see any reason why it wouldn't be able to go faster than 25, that's basically idling in 4th gear.
mcalli5ter
Jan 25, 2010 07:32 PM
cjcathey2002
Feb 27, 2003 11:11 PM
yakimakanutt
Jan 15, 2002 08:51 PM
