08 F150 - P0743 Code -Need Help!
Old Sep 23, 2023 | 01:08 PM
tonyguns's Avatar
tonyguns
Hi guys, I have been struggling with this code for about a month now, to no avail. let me run you through what I have fixed an or replaced so far with no luck
1. Wiring loom - removed from the truck, fixed all broken wires, there were several.
2. Replaced all the external shaft sensors with OE ford parts.
3. Replaced the Torque converter solenoid with OE ford part
4. Rep[laced the plastic wiring loom that runs inside the transmission - (RockAuto)
5. Fixed the ground strap that runs under the passenger side wheel well
6. Fixed and cleaned the ground wire under the passenger side kick panel right behind the fuse block
7. Cleaned all firewall grounds with wire wheel and applied a product called No-Ox.
8. Just took it out for a drive and beat the living **** out of it because pissed.
What am i missing? I am flat out of ideas. it runs and drives fine, just flashes the overdrive light and has a transmission malfunction warning on the dash. Any help would be great!
