Timing set
Old Sep 13, 2023 | 04:42 PM
Bvretn1's Avatar
Bvretn1
Timing set
Old Sep 14, 2023 | 06:24 AM
DaveMcLain's Avatar
DaveMcLain
The early engines used a timing set that's "straight up". The EFI engines also used a timing set that was not retarded. The difference is on the crank gear and it is easy to see by eye. The dot on the lower gear is directly in line with the keyway. On the retarded(8 crank degrees) set the dot is noticeably offset. You could move the crank backward or the cam forward and it would do the same thing. Swapping this makes a real difference in idle quality and overall low speed performance.
Old Sep 19, 2023 | 01:37 PM
Bvretn1's Avatar
Bvretn1
Thanks! After putting in the straight up timing set do I set the base timing at 8° according to the emissions tag under the hood?
Old Sep 19, 2023 | 03:03 PM
DaveMcLain's Avatar
DaveMcLain
The timing will change by 8 degrees more advanced so you will have to reset that and I'd start with the stock setting.
FordmanShane
Jun 10, 2012 07:19 PM
78fordranger
Jul 16, 2006 09:14 AM
jwgeorge
Aug 28, 2005 01:45 PM
mositso
Jun 17, 2003 08:56 PM
