wire brush to get all the loose stuff off.....spray a DESALT over everything to get rid of any remaining road salt... wash off with soap and water... let dry ... paint RUST CONVERTER on everything... it turns the rust to a black oxide ... then paint with enamel paint
If you dont Neutralize the salt film, the paint will fall off in a year.
AGS Rust Solutions Road Salt Neutralizer, AOR-86 - Cleans Salt & Prevents and Protects Against Rust and Corrosion - 1 Gallon of Concentrate to 26 Gallons of Solution
