compression!
Old Nov 20, 2003 | 12:43 AM
3eggOmelet's Avatar
3eggOmelet
compression!
ok, i figured this would be the place to put this one.
i'm doing a ground up build for a 351w/408 stroker and want to supercharge with a whipple. i want to be able to run pump gas (92 octane), and i was hoping to put out about 12lbs of boost.
most people i talk to say a normally aspirated motor shouldn't be run over 11:1 to stay on pump gas.
i'v read a few articles that state that the engines 'effective' boosted compression can be MUCH higher than you would normally build a engine for (like 18:1 under full boost), i used this article:
http://www.motorsportsdigest.com/forced2.htm
to figure that i could build my motor for 9.5:1 compression and with 12lbs of boost still only hit 17.3:1 effective compression. this sounds prety darn good to me.
this motor will see light street/strip use in my '91 f-150.
anyone see any problems with this?
Old Nov 20, 2003 | 12:20 PM
Freightrain's Avatar
Freightrain
Bascially you need less static with MORE boost. Seeing this is a "street" motor, I think you will be okay. You definitely want to watch your a/f ratio. Detonation is a key factor in making it stay together.
I've watched some friends put motor after motor together from playing on the ragged edge with there superchargers.
Larry
Old Dec 10, 2003 | 08:01 PM
adilts2002's Avatar
adilts2002
ok first of all i say ur risking ur money here a 351 w/408stroker? ok if that is right u have to bore it out what .040?? in this case i would hesitat running it over 2000 rpms letalone a supercharger. i would get the lowest compressin piston i could find and only run about 5 lbs thrust on it if u want it to last more then a year
Old Dec 13, 2003 | 02:36 AM
Blurry94's Avatar
Blurry94
A 94 Lightning with a built 408 stroker ran a 10.9 in the quater runnin' (i think) 14lbs of non intercooled boost. I would suggest running an intercooler though...much lower discharge temps and you can run more timing. In the end, it's all about the tune.
Old Dec 16, 2003 | 03:32 PM
F150daniel's Avatar
F150daniel
you need about 8.5:1 com. to run 9 psi non intercooled.
264WSM
Feb 28, 2018 09:36 PM
mcpaul05
230
Feb 5, 2018 10:25 AM
Sous
89
Sep 29, 2016 04:06 PM
Rusty_S
Jul 22, 2015 01:40 PM
hustler54
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 30, 2014 01:51 AM
