1996 f250 map sensor
Old Aug 10, 2023 | 10:04 PM
Terdman05's Avatar
Terdman05
After testing my map sensors voltages I’ve noticed everytime it’s humid it rains I get a limo code from it and a check engine light. Today I sprayed it with wd40 to displace the water and it worked perfect but after a heavy heavy rain on the way down the engine cut off when I stopped from the same thing. I again sprayed it with oil and it was fine. Does anyone has a solution to stop water from getting to it? Or do you think I need heat shrink new covers on the wires where they were tapped? Idk if the sensor it self is getting moist or just the wires
Old Aug 10, 2023 | 11:24 PM
Conanski's Avatar
Conanski
Is the rubber hood seal stll present? What about the rubber seal on the MAP electrical connector? It's possible the sensor housing is cracked and letting moisture in so you might just replace it anyway... that is a common problem with ignition coils too.
R&RFord
41
Apr 4, 2021 06:27 AM
halleva
Jun 9, 2017 09:05 PM
Zwalters
Feb 3, 2016 07:26 PM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
BigBlue88
18
Dec 22, 2004 09:24 PM
