Spring Rate
Old Aug 9, 2023 | 03:54 PM
RTT's Avatar
RTT
Spring Rate
What is the coil spring rate of a F103 with GVW of 4500lbs ???
Also , what are the dimensions of the coil spring ??? Thickness , height & width , & any other.........
Old Aug 10, 2023 | 02:07 AM
RichS2659's Avatar
RichS2659
Here you go:
https://www.fordification.com/partnos/springs-front.htm
Old Aug 10, 2023 | 02:37 PM
RTT's Avatar
RTT
RichS259 U R the MAN !!!
I found some brand new springs I think have almost the same rating , & l think the same size .
I measured them several moons ago..........but hard to get a measure with springs on the truck.
Now if I can only find the actual Ford dimensions !!!
Thank-you so much , I have a Ford catalog , but have a little trouble finding info , & I did not dream that would have the spring rate ! I must try harder to figure out my catalogs !
As I said now I need the dimensions ?????????
Thanx again............
Old Aug 11, 2023 | 10:59 PM
RTT's Avatar
RTT
1290lbs. average capacity at pad is how many lbs./in...
Slick collector
Apr 28, 2023 07:43 PM
Anatta
Apr 6, 2023 10:46 AM
mic91F150
Dec 23, 2015 09:12 PM
WC76TX
Jul 3, 2002 10:56 AM
