Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Decode my vin please
Old Jul 30, 2023 | 12:03 AM
Sally88's Avatar
Sally88
2nd Gear
Have a 1966 f600 but I need to know engine and transmission info so I can order parts. Just bought from someone and they knew very little about it. The VIN is F6DC0D58703. Any information would be amazing.
Old Jul 30, 2023 | 01:54 AM
85e150's Avatar
85e150
Moved to Large Truck.
Welcome to FTE. This forum deals with the larger trucks and you'll get more info on your truck here.
There is a problem with your VIN.
The 3rd character should be a number, either 0 or 1 for your model year.
The serialized number D58703 is for model year 1968, not 1966.
The transmission is not indicated in the VIN. Does the truck have a warranty plate on the driver door? And does that VIN agree with the title?
With the VIN, here is what we have:
F60 = F600 gas, 4x2 (assumes F60 instead of F6D)
C = 330 2V MD FT gas V8 (Medium Duty, uses a cast crank and FE oil pump drive and other FE bits)
O = This is for the assembly plant and there is no plant with "O" as the code.
D58703 = 1968 numerical series, July 1968 production
The biggest concerns on these are wheels and brakes.
Read up on wheels and take a good look at what's on it.
https://www.ford-trucks.com/forums/8...l#post19892682
Does it run, stop, turn etc?
Old Jul 30, 2023 | 04:11 AM
Sally88's Avatar
Sally88
2nd Gear
Have to replace pressure n clutch first but that is the VIN on all the paperwork. Have not been able to locate on frame yet.
Old Jul 30, 2023 | 06:54 PM
85e150's Avatar
85e150
Given the jumble in the VIN, you might have a code D engine--again a 330 2V but a HD engine.
Look at the engine and see if the intake manifold extends under the valve covers.
Do the plugs angle like so: //\\
2BBL carb?
2 bolts at each exhaust port, and 2 more bolts lower on the exhaust manifold in the center of the manifold?
If it were mine and I need a clutch, I would take it apart and duplicate what's in there now.
You should probably have the flywheel resurfaced while you're doing the job.
farmermike1
Large Truck
Jun 5, 2022 04:42 AM
N61870
Large Truck
Nov 12, 2021 09:38 AM
Steve Noland
Dec 16, 2016 11:40 AM
