I'm new here!
Old Jul 6, 2023 | 12:09 PM
3357's Avatar
3357
5th Gear
I'm new here!
Hello All, recently acquired, new-to-me '99 F450 with the 7.3 powerstroke.
I've put less than 250 miles on it, was running fine and then all of sudden began running extremely rough. From what I've found here the evidence points to a miserable under valve cover harness 9 pin connector (also, the outfit I bought the truck from mentioned they had to "fix the right side 9 pin connector so that it was tight").
So, have my multi-meter here and about to head out and dig in, perhaps left side first--if I can assume the previous owners fixed the right side adequately.
While I'm here, the truck was built in April '99 and I've seen mention of "early vs late" '99s. Safe to assume being built in April makes it an "early"?
Old Jul 9, 2023 | 10:06 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Not many folks that know about this sort of thing frequent the "New Member Introductions" forum. You'll probably have better luck starting a thread over in the "1999 to 2016 Super Duty" forum.
Welcome aboard!
Old Jul 16, 2023 | 08:41 AM
3357's Avatar
3357
5th Gear
I was wrong, the passenger side 9 pin under valve cover connector had come loose again. The dealer I bought it from evidently merely pushed the connector back in without addressing the real problem--tightening the connector so it would not come loose. I did the $.25 fix found here on FTE and it's been running like a champ. I suppose I should do the same to the driver's side for peace of mind.
Old Jul 20, 2023 | 12:24 AM
CathedralCub
FTE Community Team
Great fix!
Thanks for letting us know what you found!
Copperspur7
Jul 20, 2023 12:25 AM
Aplatt
Site Announcements
Apr 16, 2021 07:39 AM
really ole man
Nov 14, 2017 08:11 PM
SactoJake
Apr 8, 2008 12:52 AM
shuck
Jul 23, 2007 07:01 AM
