Problem with my Ford TBC
Old Jun 12, 2023 | 08:26 PM
Motohead911's Avatar
Motohead911
I have been chasing a problem with my factory installed trailer brake controller. When I apply the manual slider I get a rapid pulsing of the brakes and brake lights.
I tested the truck with a know good controller and it did the same thing, and I test the controller in a good truck and it worked normally.
I was wondering if anyone else has had a similar issue?
The code i was anle to pull from the TBC was C2803, pressure transducer.
Old Jun 12, 2023 | 09:16 PM
bismic's Avatar
bismic
Check fuse #12
Old Jun 12, 2023 | 10:00 PM
Motohead911
Thanks, I did check #12, along with every other fuse that deals with brake lights, turn signals, and the TBC.
I went through the WSM for the C2803 which is Pinpoint Test C for the auxiliary brakes. By following the test tree looks like i need a new master cylinder. Damn. Has anybody else been down this road?
Old Jun 12, 2023 | 10:08 PM
bismic's Avatar
bismic
Do you have any network communication (U) codes?
Old Jun 12, 2023 | 10:11 PM
Motohead911
I did have an U1900 but I cleared it and it hasn't come back.
But that could have come from unplugging and plugging the controller.
Old Jun 13, 2023 | 06:55 AM
bismic's Avatar
bismic
Possible.
Do you remember the module that threw that code though - the scan tools will show that.
I ask because a network communications issue (U1900) with the ABS module can cause the code you posted earlier to be in the TBC module, and cause the behavior you describe.
Old Jun 13, 2023 | 10:16 AM
Motohead911
Ok thanks Mark. The U1900 code still has not returned and the C2803 does not clear.
Old Jun 13, 2023 | 10:29 AM
bismic's Avatar
bismic
Well, I'm stumped. Sorry. It clearly isn't the TBC module though - at least I wouldn't think so if it works fine in another truck.
Old Jun 13, 2023 | 10:56 AM
Motohead911
I know, I am also. I hate to waste money, but the WSM sent me to replace the master cylinder, so I ordered one. Hopefully it fixes the problem.
Old Jun 13, 2023 | 11:08 AM
bismic's Avatar
bismic
Interesting. I know you will, so as usual - keep us informed!
Old Jun 13, 2023 | 12:48 PM
Motohead911
I will follow up after I get the master cylinder. I missed your question earlier about which module showed the U1900 code, it was the TBC.
Old Jun 14, 2023 | 08:18 PM
Motohead911
Just a quick update, the master cylinder has been discontinued. So I am thinking about my next move.
Old Jun 15, 2023 | 07:00 AM
bismic's Avatar
bismic
There are several aftermarket solutions for a brake master cylinder if you feel its replacement truly is necessary.
https://www.rockauto.com/en/parts/fo...+cylinder,1836
Personally, I would call up AutoNation White Bear Lake, ask for Internet sales, and see if they couldn't track on down for you.
carolinaborn82
2009 - 2014 F150
May 25, 2017 05:26 PM
ad326
All Things Towing
Jun 8, 2013 10:27 PM
joegebff
15
Oct 11, 2008 09:49 AM
igotjam
All Things Towing
16
Nov 9, 2007 07:11 PM
jomac11
All Things Towing
19
Oct 31, 2007 12:55 PM
