77 am/fm install problems
Old Jun 5, 2023 | 02:05 PM
magicrat56's Avatar
magicrat56
Trailering
well I'm back with more radio issues, just received a truck am/fm radio for are 77 F-350; a lot shorter overall BUT I can't seem to install it because AGAIN it wont allow me to fit the dash bezel flush, almost like need shaft extensions to make it work.Has anyone had this much trouble? On the drive home I just wonder if the repro dash bezel is the problem? From what i have seen the radio sits behind the bezel and not thru it is that right? If it sits behind then the bezel is not the problem.From what I see in the manual,no spacers or anything that looks odd. I have 2 radio/heater mounts and they are both the same. When I go back to work I will get the numbers off the radio if that helps.
magicrat56
13
Jun 3, 2023 06:57 PM
GamerGirlAlice
Dec 31, 2013 08:35 PM
Jtham
Sep 25, 2012 05:55 PM
powerstrokin007
Nov 20, 2007 07:54 PM
R100RT
Apr 18, 2003 11:14 AM
