Greetings y’all,
I have a 79 f250 4WD with a 400 6.6 I am restoring. It is time to change the differential fluid but I want to ensure I know exactly which differentials I have. I have read some posts but I do not want to lean on my own understanding and would like y’all’s help. The front differential the tag reads: 3 54 d8ta aec 610040-2. Rear diff reads: 3 54 d8ta Ada 603900 12. From what I can gather, the front diff is a Dana 61? And the rear a Dana 60? Is this correct? Thank y’all for the help much appreciated!
90% ish, or some such number of 4wd 1979 F250 have a Dana 60 rear and a Dana 44 9F front axle. They both take your basic 80/90 gear lube. If you do have a Dana 60 (not a Dana 61) front axle, you are lucky. Those are worth a lot of $$ these days.
Front axle steering knuckles attached to the axle by 2 upper and lower ball joint (one big castellated nut on top)? ='s Dana 44
Same set up but attached with 4 bolt capped kingpins.='s Dana 60
The front differential tag reads: 3 54 D8TA-AEC610040-2 //Rear diff reads: 3 54 D8TA-ADA603900-12.
From what I can gather, the front diff is a Dana 61? NOT!
Ford: D8TA-AEC / Dana: 610040-2 = Dana 44-9F Front Driving Axle // 3.54-1 // Free Running Hubs // No Limited Slip // 3,800 lbs. Front Axle Capacity // Parts list # 30.5Q
Ford: D8TA-ADA / Dana: 603900-12 = Dana 60 Rear Axle // 3.54-1 // No Limited Slip // 5,300 lbs. Rear Axle Capacity // Parts list # 93.
