Yet another P0430 Thread (it has returned)
Had him replace both cats (was only $50 more to get both, so figured why not), exhaust manifold, replaced all 16 plugs which had never been replaced it seems, and B1S2 O2 sensor that was also bad.
Everything has been fine since then. Codes all went away, power is good, no issues at all. Though mileage is a bit less than expected. I am not towing anything, mostly highway miles and getting around 8-9. I get that is close, but still think it should be a little better.
I am about 1,000 miles into this repair. I happened to be towing for the first time since I got the truck (just a 5x8 come along and bed loaded with items we are moving out of storage, so nothing crazy. Oddly, as I was hooking the trailer up, I did have the thought that the exhaust did smell a little rich but thought, eh, this is my first Ford and my first SD, so maybe that is normal for such a truck. After a few trips over a couple of days moving items, I was returning the trailer to my father in law and lo and behold as I was pulling in, I noticed that the CEL was on.
Pulled out my Forscan tablet, hooked it up, and WTF - P0430...again! I am at a loss because other than the rich smell, I have no symptoms of anything else.
No power loss
No smoke, literally none at all, not even just a puff on start-up
No other codes
No misfires felt (but no CEL thrown)
No oil consumption
No coolant loss
Normal operating temps
I have only done a very preliminary monitor of the sensors, but nothing looks majorly amiss. There is some movement of the B2S2 O2 sensor, but it certainly isn't jumping dramatically nor tracking with the B2S1 O2 sensor.
I reset the CEL and it has stayed off, but I do see it in pending faults so it detected the same issue again. Whatever it is. I would imagine that if a cat was getting borked in just 1000 miles, I'd certainly be seeing some other pretty significant symptoms elsewhere. Am I off on thinking that?
Any ideas or suggestions here?
I think I'll try to swap the after cat sensors (I think they are the same), reset the code and see if it switches sides. Best case scenario really. Change the o2 sensor and be done. If still on the same side, I may try to make sure my injectors aren't sticking even a little. Sans an additional symptoms, I may just go the non foulers and ride off I to the sunset.
Appreciate the response.
Mike
Not that it would necessarily affect mileage specifically, but have you looked for misfire counts?
Start by examining your short and long term fuel trims to see if they're running skewed. Bet they are... Most likely issues there would include a dirty MAF sensor or a vacuum leak.
Leave the downstream sensors alone, they won't cause your issues.
Denny
I looked more into the mpg and realized I gave incorrect info. I got that info from Forscan without any calibration. Not sure where it gets that info from, but the dash says average is 10.5 so a little more close to normal. I also failed to mentioned I put 295/70R/18 Wildpeak AT3s on it, so there is a small effect there on MPGs as well. So I think it is still a little low, but not as far off as I initially indicated. Still have an issue though that I need to sort out I do plan on doing the more tried and true method of MPG determination by filling up, noting the mileage, driving, then filling up again, divide gallons into miles. I should do that simply to know regardless anyhow.
As far as the downstream O2 sensors. I know they don't do anything to affect or cause an issue, but I figured an easy way to test for a possibly faulty sensor would be to swap them and see if it starts giving me a P0420 instead. Probably a low chance, but I've seen stranger things.
I'm with you on vacuum leak, but unsure about dirty MAF sensor in this case...if it was this, wouldn't I probably be getting both P0430 and P0420 since it's just one sensor that would affect both?
Nonetheless I agree look at fuel trims. I honestly don't know if a dirty MAF would trip both sides in reality (I agree it should in theory) but it's easy enough to pull it and clean it.
If you mess with your downstream 02 it's in the top of the cat. Be careful as the bung is just lightly induction welded in there. Tip: next time ask your exhaust guy to weld it in more solidly
My mini-saga here (since all your stuff is new it should cooperate):https://www.ford-trucks.com/forums/1...l#post19650247
To start, I ran a Mode 6 test and there actually are 16 misfires only on 3 and 5 I'm the past 10 driving cycles. Nothing to set codes and the "overall" numbers it gives us 0 so not sure what that's about. Doesn't tell me a ton since that's one on one bank and the other on the other bank.
Watching fuel trims, it actually looks pretty darn good. The STFT on. Both sides are fully in sync and are about -1.25 on average, so it does indicate a bit of a rich condition, but nothing id consider significant in any way. I am not in front of the ta let I use for Forscan. I saved screenshots of the info but can't post them currently. The LTFT was also really good and basically real close to even both sides as well.
Here's the interesting part. So I reset the code about 3 days ago. And it came back night before last. It stayed on for about a day, but as I was pulling into the house late last night, I noticed that it cleared itself! I guess that is at least good news in that it doesn't seem to be the cats, I don't think.
I wonder if towing those few days has anything to do with it? I was towing a come along with a lot of household items, furniture, boxes, etc. Had it on tow haul mode. Code seemed to throw after I towed a few days on tow/haul mode. Then went away after I stopped towing and hauling for a few days.
Denny
