96 E350 E4OD problem
Old May 27, 2023 | 03:30 PM
BigDan1's Avatar
BigDan1
Unhappy 96 E350 E4OD problem
1996 E350 based 22 feet Class C RV , ( 7,5L / E4OD )
We are stranded near Richland Missouri
We were driving on rte 44 eastbound when the transmission started to go up in temp , fluctuating from 185-210
suddenly blue smoke all over
barely had time to get off the exit that was a mille away ,,,,,
stopped at a small truck stop ( oasis travel plaza )
shut the engine , looked under , tranny is leaking badly from around torque converter area
let it cool down ,
removed the rubber plug under the bellhousing , checked the t/c drain plug , removed the protector plate ,cleaned all area ,
, added 5 qts of oil , started the engine , almost instantly it started to leak from what seems to be behind torque converter
could it be just the torque converter seal ???
never saw that before , but if anyone here had this problem ,Ill rely on it !
Îm car mechanic by trade , but on vacation , dont have all the tools in the RV
what to do ?
thanks
Dan
Old May 27, 2023 | 03:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it is most likely the torque converter seal. When replacing this seal you should also replace the bushing behind the seal. There is an aftermarket seal made from Viton that is MUCH better than the factory seal.
As you probably know the trans needs to come out to replace this seal.
Old May 27, 2023 | 07:43 PM
BigDan1's Avatar
BigDan1
thanks Mark , I rely on your knowledge 🤗
my big concern is
did the tranny suffered ?
should I just get the seal changed or should I get it rebuilted ?
at home I would do the seal easy ,I have all the tooling ( mechanic for 40 years )
but being on a roadtrip , I have to get a shop to do the job $$$
Dan,
Old May 27, 2023 | 08:00 PM
Mark Kovalsky
Chances are it isn't damaged. If the trans was working well up to this point I would change the seal and bushing, not rebuild it.
Old May 27, 2023 | 09:15 PM
BigDan1's Avatar
BigDan1
when it started leaking , huge smoke because of exhaut header Y pipe passes under bellhousing ,I ran about 3 miles to get out of highway , when it started slipping, I stopped immediately
still think I should do the seal only ?
thanks 🤗
Old May 27, 2023 | 09:21 PM
Mark Kovalsky
I would...
Old May 29, 2023 | 01:18 PM
BigDan1's Avatar
BigDan1
I would...
Mark
found a CR ( SKF ) seal # 19966. Descibed as a Silcone seal , does silicone meens viton type ?
thanks
Dan
Old May 29, 2023 | 01:30 PM
Mark Kovalsky
No, I don't think it does.
Here is a Viton one I found on Amazon:
Amazon Amazon
Old May 29, 2023 | 08:56 PM
etinpa's Avatar
etinpa
For information:
Viton® is a specific brand of Fluorocarbon (FKM) and is a registered trademark of The Chemours Company. This synthetic rubber polymer is commonly used in o-ring applications for aircraft engines, automotive fuel handling systems and other applications requiring high temperatures and low compression set.
Old May 30, 2023 | 04:23 PM
BigDan1's Avatar
BigDan1
Mark ,
nobody can either help me or do the job for at least 2-3 weeks
decision : found a transporter to bring the rv home !
at home Ill drop it , and do whatever it needs
what would you recommend as a rebuild kit ?
Any items that I should give a closer look ?
you ‘re the tranny man 🤗
thanks again
Dan
Old May 30, 2023 | 08:22 PM
Mark Kovalsky
I've used Transtar1 kits with good results.
Old May 30, 2023 | 08:24 PM
BigDan1's Avatar
BigDan1
I take good note !
Old Jun 11, 2023 | 03:37 PM
BigDan1's Avatar
BigDan1
Mark,
we are home now , finally after two full weeks in a truck stop
I tried to move the RV , woulndt move at all ( oil level full )
With your knowledge, would you think that it.s worth rebuilding it ( not too much damage inside beside regular rebuild kit ) or should I find another one and rebuild that one ?
Thanks
Dan
Old Jun 11, 2023 | 08:58 PM
Mark Kovalsky
It depends on what the internals look like. You need to open it up to see if it's worth rebuilding. It could be a fairly minor failure, or it could be junk inside.
Black Ford XLT
1978 - 1996 Big Bronco
Jul 25, 2010 04:02 PM
TNScrambler
Jul 20, 2010 12:41 PM
DonniW2448
Aerostar
Jul 20, 2006 06:59 AM
samhihn
May 26, 2002 09:34 PM
