Decoding DSO Code
Old May 22, 2023 | 12:34 PM
Ivywells38's Avatar
Ivywells38
3rd Gear
Decoding DSO Code
Okay so I recently purchased a 78 f150. On the vin plate on the door sill the color spot is blank and it has a 6 digit DSO code, meaning the truck was a special order. The DSO code is 522555, now I know what the first 2 digits mean but the last 4 mean special order and I’m trying to figure out what was specially ordered and what paint color my truck is.
Old May 22, 2023 | 01:14 PM
85e150's Avatar
85e150
I can't recall the source and I'll try to find it, but I think the last 4 are simply sequential numbers for the model year.
So your truck is the 2,555th special order of the year.
A Marti report might be available for your truck--again something we need to check on.
Old May 22, 2023 | 02:25 PM
5851a's Avatar
5851a
If you can find your build sheet, usually in seat springs. Other locations, behind door panels, under floor covering. They are hit and miss. If it's a non-Ford color, it will be noted on bottom of build sheet and the paint supplier code usually. Ford paid the workers to read the build sheets but not to throw them away so they stuffed them wherever was convenient. That was my understanding and I have found non stock paint suppliers on a 78 and 79 Ford on the build sheets. When I worked in a body shop.
Old May 22, 2023 | 06:01 PM
85e150's Avatar
85e150
Marti Report, $20 for the basics:
https://www.martiauto.com/index.cfm
The full 6 digit DSO code would have been used by Ford to track down what the order was, but I doubt your local Ford Dealer could help you with a '78.
samkeele1
Nov 21, 2022 02:15 PM
93flareside351w
Apr 27, 2016 05:03 PM
ajchapman3
Jul 22, 2013 03:50 PM
James1966
Oct 21, 2008 02:27 PM
mark914
Nov 23, 2007 09:18 PM
