I have a broke coil spring retainer that holds the coil spring on the top bucket, I know they are obsolete, does anybody have an idea on what I could use that might be a close match?
C6TZ-5B300-F .. Coil Spring Retainer - UPPER / Obsolete
1965/70 F100/250 2WD - 1971 F100/250 2WD before serial number L80,001.
Basically like this, except this is for 4x4, I have two of them off another project and they do not line up, I’d have to cut and weld to make it work and even if I did that I’m not sure how well it would line up
