Trans & VM Question
Old Apr 22, 2023 | 11:15 AM
MrDormouse's Avatar
MrDormouse
Trans & VM Question
Hello forum,
So, I think the Vacuum Modulator is bad as I get a high RPM hard shift into 2nd from 1st. I cannot for the life of me locate it on the transmission. My Door Code for the Trans is T which I believe is C6 (truck has Auto OD). Now, I do not see a line to follow from that 3rd firewall spot (empty) and not sure on the manifold tee. For all I know it is completely removed. Does anyone have a picture of where I may find this on the Transmission so I may replace and be certain it's even hooked up?
84 F150 302 2wd Auto w/ OD
Thank you
Old Apr 22, 2023 | 12:13 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The C6 is a 3 speed without overdrive
The vacuum modulator on a C6 would be on the passenger side of the transmission. I have never owned an AOD but I would look there.
EDIT: Now that I think about it, it could be that the throttle cable needs to be adjusted.
Old Apr 22, 2023 | 12:50 PM
Max Capacity's Avatar
Max Capacity
Here are pictures of my AOD tranny.
Here's what I use for fluid in it.
Old Apr 22, 2023 | 01:00 PM
Max Capacity
You need to make sure the fluid level is correct and clean. Because the pan is so hard to remove, I just use my suction gun to suck a couple of qt's out and fill with new stuff. But mine hasn't had any issues.
Old Apr 22, 2023 | 01:32 PM
diggerrigger's Avatar
diggerrigger
EDIT; For OP. The AOD has no vacuum modulator. There is a cable from a lever on the transmission shift shaft to a lever on your carburetor. This (TV) Throttle Valve Cable should be neither tight nor loose. A misadjusted cable can cause your hard shift symptom.
Old Apr 22, 2023 | 01:40 PM
diggerrigger
EDIT: For MaxC. The transmission mount does "look" a little rough in your photo. Place a jack under the tail shaft and see if it lifts off the cross member.
If you want to drop the pan, unbolting the transmission mount and raising the rear will give you easy access to the 10mm bolts along the back of the pan.
The Mercon V is the correct fluid.
Old Apr 22, 2023 | 01:46 PM
Max Capacity
Thanks but I don't notice any movement in my AOD from that mount. Mine shifts fine. I was just posting photos for the OP.
Old Apr 22, 2023 | 03:51 PM
Franklin2's Avatar
Franklin2
Originally Posted by MrDormouse
Hello forum,
Thank you
Sounds like the cable is a little too tight. But tighter is better than too loose. You do not want a too early soft shift. You should be able to release the cable outer sheath at the carb or throttle body, use your hand to open the throttle wide open (engine off) and while holding the throttle wide open, lock the sheath back in place.
Old Apr 23, 2023 | 03:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
,So, I think the Vacuum Modulator is bad as I get a high RPM hard shift into 2nd from 1st. I cannot for the life of me locate it on the transmission.
84 F150 302 2WD Automatic Overdrive
Your truck has AOD (Automatic Overdrive), not a C6!
Old Apr 23, 2023 | 04:20 AM
NumberDummy
AOD does NOT have a vacuum modulator valve, your applications are wrong as is the shift lever display.
AOD introduced in 1981 F100/250 302, the 300 I-6 was added in 1983 // 1984 E150/250 300/302 // 1985 Bronco 302
It's P-R-N (O) not D
Old Apr 23, 2023 | 04:30 AM
My4Fordtrucks
I stated that I have not owned a vehicle with an AOD so I wasn’t sure about the modulator. I also mentioned that it could be that the cable is out of adjustment.
It sure looks like the letter D in a circle to me
Old Apr 23, 2023 | 06:34 AM
MrDormouse's Avatar
MrDormouse
Hello.
Awesome everyone, thank you. So, not have the VM is a good reason I couldn't find it
I do see that cable to the carb though. I will adjust it just a touch.
NM_91IDI
15
Mar 8, 2016 10:47 AM
bomberboat
Oct 27, 2008 01:45 PM
vinnybean
Jan 15, 2007 04:31 PM
Shovelhead 93
Jan 6, 2006 06:30 PM
