CPS tach movement
Old Apr 6, 2023 | 05:17 PM
85Ford's Avatar
85Ford
CPS tach movement
Hey does anyone know if Forscan will still read your RPM’s if the CPS is bad?
I’ve got a crank no start, tach is moving very slightly & when connected to Forscan I can see my RPM’s.
I’ve already gone down a rabbit hole checking other things so I’m just now seeing if I overlooked the CPS.
Old Apr 6, 2023 | 07:33 PM
z31freakify's Avatar
z31freakify
Is the engine spinning fast enough?
is voltage above 10.5 while cranking?
How are you batteries and terminals?
Old Apr 7, 2023 | 08:32 AM
knottyrope's Avatar
knottyrope
if CPS is bad, PCM cant read RPMs
if tach isnt moving, then CPS is bad or the wires to it are shorted, broken etc
Old Apr 7, 2023 | 08:44 AM
97-psd's Avatar
97-psd
Forscan is only going to see rpm if the CPS is working and sending a signal. How many rpms is it showing?
Old Apr 7, 2023 | 09:15 AM
85Ford's Avatar
85Ford
it was showing 100 RPM’s. I put a new starter in and can audibly hear it cranking faster, but can’t get Forscan to connect again and read the RPM’s.
Old Apr 7, 2023 | 04:42 PM
85Ford's Avatar
85Ford
cranks good, almost 11V while cranking. Cleaned the terminals.
MeTo
32
Nov 12, 2021 09:16 PM
TransplantX
Sep 27, 2008 05:44 PM
Jay-re
Apr 15, 2007 05:33 PM
Joe98684
Mar 9, 2006 04:11 PM
mybigredford
Feb 1, 2004 02:23 PM
