Gauge wiring pass through
Old Mar 24, 2023 | 02:51 PM
kd5zll's Avatar
kd5zll
Just what the title says... where have you folks passed your gauge to sensor wirimg through? I have a fuel pressure unit i need to stop staring at, and just hook up.
Old Mar 24, 2023 | 03:15 PM
Dan V's Avatar
Dan V
Well, there are some "pass through" wires on the driver side firewall.
Old Mar 24, 2023 | 03:17 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
On my ZF6 truck and for my three pillar gauges, I simply made my own passthrough in the firewall above the pedals and behind/under the dashboard. Been working well for many, many years. On the passenger side there is a passthrough in the footwell near the down pipe or you can come through near the heater core behind the glove box.
Old Mar 24, 2023 | 03:38 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The shift cable boot makes a nice one for the EGT thermocouple and the transmission temperature.
I know, you're just doing fuel.
The plastic cover for the unused clutch master cylinder is always a good go-to on an automatic truck.
Old Mar 24, 2023 | 04:05 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
I like to go up through the auto shifter grommet on the floor right behind the accelerator pedal. Very hard for water to flow up into the cab that way.
I use the same location on a manual truck. Drill a hole in the floor behind the accelerator pedal. Works great
LongRider
General Automotive Discussion
Jan 28, 2022 03:46 PM
flatbedfordguy
May 15, 2018 11:53 AM
Rentaro
16
Jul 31, 2013 09:10 AM
KevinC.
Jul 20, 2010 12:25 PM
Keepitrunnin
Mar 11, 2008 10:51 AM
