gas tank swap
Old Feb 27, 2023 | 05:42 PM
spooktn's Avatar
spooktn
gas tank swap
I knocked a hole in my 2000 ranger gas tank and i hav e a doner 1997 tank but the fuel pump is different and has 4 wires and my 2000 only has 7 wires, is there any way this will work ?????
Old Feb 28, 2023 | 11:12 AM
Hank85713's Avatar
Hank85713
will the old pump fit the tank or are they totally different. Autozone sells pumps (I have one for years on my 94) so just either transfer your old one if it fit or buy one to replace it with .If needed buy a elec schematic and see what goes where with the 7 wires Its has probably something to do with dash panel readouts (?).
Old Feb 28, 2023 | 03:18 PM
spooktn's Avatar
spooktn
They are totally different . I will check local parts dealers to see if i can get a pump to fit. Where can I get a electical schematic ??????
Old Mar 1, 2023 | 11:53 AM
Hank85713's Avatar
Hank85713
do a search for 2000 ranger electrical schematic, they used to run about $15-20.
Old Mar 1, 2023 | 03:26 PM
spooktn's Avatar
spooktn
I have a fuel pump I can jerry rig in on the wiring to make the pump run ,,, but I will not be able to put the fuel pressure sensor in . Will it run without the sensor or is there a way to bypass it ????
Daylene Alford
Apr 4, 2017 11:00 AM
mustangman65_79
Oct 23, 2011 10:51 AM
yooperman4x4
Feb 7, 2011 09:50 AM
JohnMcHugh1
Jul 16, 2007 04:25 PM
