Brake Size
Old Feb 23, 2023 | 12:19 AM
RTT's Avatar
RTT
Exclamation Brake Size
I need back brakes parts right & left . Both metal cables are bad . Are these parking brake cables ? More importantly are my brake shoes 11" x 2 " or 11" x 3 " ???
I cannot get front drums off....... yet
Where good place to buy brake parts ???
Old Feb 23, 2023 | 07:46 AM
Eric Hamilton's Avatar
Eric Hamilton
RTT, I found that NAPA is a good source for the emergency brake cables, and Rock Auto a good place for pads and spring kits. Your 71' F100 should have a Ford 9" rear end...confirm with your vin number and pictures. My 71' F250 has a Dana 60, which takes 2.5" pads and the axle has to be removed to pull the drums. Can you remove your drums once the wheels are off...might be the best way to ensure you buy the correct parts.
Old Feb 23, 2023 | 08:16 AM
chirkware's Avatar
chirkware
If you are doing rear brakes on a Ford 9", I really like this hardware kit:
carlson H2313 Rear Drum Brake Hardware Kit https://a.co/d/1HgYwjD
I've used it on both my 70 F100 and my 86 F150. It includes new auto adjusters, which makes things MUCH easier as you don't have to worry about the condition of the old ones. And the kit is CHEAP.
I've also had good luck with wheel cylinders and brake shoes directly off Amazon.
Old Feb 23, 2023 | 08:23 AM
chirkware's Avatar
chirkware
I got parking brake cables off Rock Auto. Here's a screenshot that shows the part numbers. Verify then for your truck of course but they fit my 70 shortbed just fine.
Old Feb 23, 2023 | 08:24 AM
Jakespeeds's Avatar
Jakespeeds
I just finished replacing everything on my 69 up to the backing plates. Everything came from Napa including cylinder pins. Everything was in stock at my Napa. I was a little annoyed at metric bleeder screws but its the world we live in. Really happy with everything I got.
Jake
Old Feb 23, 2023 | 09:18 AM
Eric Hamilton
Jake
NAPA might be slightly more expensive, but it's great to get direct from them in the event something isn't correct and you can return the part versus mailing it back.
Old Feb 23, 2023 | 09:45 AM
chirkware's Avatar
chirkware
I ran into the metric bleeders as well, but I ended up replacing my bleeders with Russell Speed Bleeders so I didn't need help bleeding my brakes, and those are SAE. Worth the extra few bucks for me.
Old Feb 23, 2023 | 10:31 AM
Jakespeeds's Avatar
Jakespeeds
I keep thinking about trying those. Then I forget. I have both a power bleeder as well as a vacuum bleeder. But I have always wanted to try them.
Jake
Old Feb 23, 2023 | 10:45 AM
RTT's Avatar
RTT
YOU GUYS ARE AMAZING WITH YOUR HELP
I HAVE BEEN SICK FOR 33 DAYS OR SO VERY slowly recovering , with emphasize on slowly !!! Your quick responses really lift my spirits
I do like dealing locally & did not think of NAPA . I do use them but kinda assumed these may be more like special parts to find. My parking /emerg cable is ok I think , the small metal cables inside the drums are what are bad.
I am really curious as to if 3 inch shoes will fit . The back drums I got off & the shoes are installed wrong so I do trust if they are the correct width . Passenger side had a spring fall out & small adjuster bracket fall when I took off drum .
I blew dust out with air & ready today to get front drums off . I think I will have drill out the spring holders or maybe turn the adjuster so maybe the shoes will shrink inside the drums so I can pull them off !!!
Wish me luck on the FRONTS !!!
As far as bleeders , great invention & like to have but they are $36 apiece , or $16 too much for me because I bought a great used Mitivac 8500 to bleed brakes by myself so will stick with the 8500 for now.
Old Feb 23, 2023 | 02:12 PM
chirkware's Avatar
chirkware
That's cool that you have a bleeder tool to use! I just have some hose, cans, and a foot. 😂
If you have an O'Reilly local to you, they may be able to turn your drums for you. I got my two original FoMoCo front drums from December 1969 turned in 2019. Not often they turn 50 year old drums! They charged me $10 each to do them and it kept me from having to separate the hubs from the drums to replace the drums.
Old Feb 23, 2023 | 02:34 PM
RTT's Avatar
RTT
Question
How do I tell if they need turning ? Look for rough surfaces I assume !
Old Feb 23, 2023 | 07:25 PM
chirkware's Avatar
chirkware
Yeah, pretty much. If the surface is grooved, they should be turned so they are smooth again.
On my 70, I had the fronts turned. The rears measured too thin to be turned so I bought new ones. On my 86, I sprayed brake cleaner on the drums (front discs by then of course), wiped them down, and called them good. 😂
Old Feb 25, 2023 | 09:41 PM
RTT's Avatar
RTT
Red face
O' close 2 me also & want $25.00 a drum . Mine look good at first glance , will check more later .........
Old Feb 25, 2023 | 10:28 PM
chirkware's Avatar
chirkware
Not surprising the cost to turn the drums went up. $10 was crazy cheap given how much time they spent doing the job. Hopefully yours are good. How did the shoes look?
BTW: Where were speed bleeders $36 each? That's about what I paid for a complete set of four.
Thunderkiss1965
Feb 22, 2023 04:30 PM
NSAJMART
Apr 27, 2021 09:30 PM
bfktwb4
WTB - Parts & other
Mar 14, 2016 12:39 PM
michael a
1947 and Older Ford Trucks
Dec 26, 2015 06:00 PM
JTyler11688
Jul 13, 2009 07:56 PM
