Flathead Adjustable Lifters:
Old Feb 20, 2023 | 04:06 PM
leonharu's Avatar
leonharu
I have a very reputable engine builder near my house that I spoke with about rebuilding the flathead engine in my truck.He informed me that he installs adjustable lifters in these engines when he rebuilds them.Last time it was rebuilt was 40 years ago and I know it don't have these in it now and it always purred super quiet.I drive my truck every day and use it like a truck!Is this a good or bad move?Please give me your thoughts.
Old Feb 20, 2023 | 06:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I assume it's a V8? This is a common way to go, has been for probably 70 years. The stock setup is really nice but requires more labor to get the valves set too the right clearance. But the stock lifters are lighter, and generally quieter. My machinist has a great deal of flathead experience and offered me a choice: $200 for a stock valve job, or $100 for one for adjustables. I went with adjustables.
Quality of the adjustables varies quite a bit, like most things today. If you go the adjustable route, get Johnsons from Red's Headers. They cost more, but have proper hardness. Note you also have to have the lifter bores drilled for a pin to hold the lifters while adjusting, which you don't want to do without a thorough block cleaning afterwards. You can try to get by with the Johnson tool for adjusting but they are miserable.
Old Feb 20, 2023 | 07:24 PM
3twinridges's Avatar
3twinridges
The hollow adjustables at Reds have a waiting list. I would get on it if you want a set from them. Used originals can be machined and I might have to go that way if my machinist is ready to go before Reds expects replenishments in March.
JB
Old Feb 21, 2023 | 08:49 AM
Klawockvet's Avatar
Klawockvet
My mentors back in the fifties were adamant about using the stock Ford lifters and valves. I would pay the extra instead of using adjustable lifters that are likely inferior quality. The problem may be in finding OEM quality originals. Bear in mind that my opinion is not widely shared in today's world.
Old Feb 21, 2023 | 09:53 AM
Don Naslund's Avatar
Don Naslund
I had adjustables in mine and I used the Johnson tool without having a pin hole drilled. The Johnson tool worked fine. I may even still have my tool in my box.
Old Feb 21, 2023 | 12:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
In the '50's, I wouldn't hesitate to stay stock. Machinists knew how to do the valves without adjustables, probably did them daily. Nowadays? They may only do it once a year, if that.
The stock lifters are a wonder, compare them to the adjustables. Not that high-RPM performance is a consideration for most flatties:
Original Ford lifter, 45.1 g.
Old style Johnson hollow adjustable, 81.9 g.
Replacement Johnson, solid with a swirl cast in, 111.1 g.
Replacement solid with a groove cast in, as found in tractors. 117.5 g.
New Manufactured Flatattackracing. 79 g.
Old Feb 22, 2023 | 10:47 AM
fh4ever's Avatar
fh4ever
NAPA put adjustable lifters in mine 42 years ago....still no issues. If your builder is reputable, hopefully he knows where to get good quality lifters.
Old Feb 22, 2023 | 03:53 PM
1952henry's Avatar
1952henry
FWIW, I believe it was Ol’ Ron on Fordbarn who said weight of lifters is not a big deal on a stock/street engine with stock valve springs.
Tanker3278
Bronco II
Aug 5, 2021 09:42 PM
Randz58
Aug 4, 2011 08:24 AM
oldwood
Jan 26, 2011 09:55 PM
puppyduks
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 2, 2009 10:18 PM
roush17996
Jan 19, 2006 09:34 PM
