Cruise control help.
Old Feb 20, 2023 | 10:28 AM
NM76F150's Avatar
NM76F150
95 7.3 with a Banks turbo kit. 5 speed.
Cruise started out intermittent. Randomly will go off, sometimes on a big bump like an expansion joint, sometimes on smooth pavement . I can turn it back on using only the resume button but time varies, sometimes right away sometimes several minutes later.
Since it works with the resume button I thought it might be the sensor on the brake cylinder so I replaced that. Also replaced the clutch switch.
Now for its latest trick, before it just cut out but now it randomly accelerates too.
Any help on what to look for next is greatly appreciated.
Old Feb 20, 2023 | 11:02 AM
z31freakify's Avatar
z31freakify
Check and see if you E brake switch is working, as that too will affect cruise control.
Old Feb 21, 2023 | 07:21 PM
RubberDuck's Avatar
RubberDuck
When I had issues with cruise, I changed out the multi-switch (blinker arm assembly) and it cured my issue.
Old Feb 21, 2023 | 07:49 PM
helifixer's Avatar
helifixer
my '97 did exactly that, it started with big bumps at first, in fact the first time was an expansion joint on a bridge then got progressively worse. I went through the trouble shooting guide that ford published and it all passed.
one day I decided I would find the problem and started tearing in to the wiring. I found a broken wire at the clutch switch, about 1/2 inch from the plug. the wire was broken but the plastic covering was perfect. the ends of the broken wire would make enough contact most of the time but bumps would interrupt it and the cruise would shut off.
coybowman
Aug 7, 2022 07:00 PM
Jeepincj7
May 24, 2022 06:05 PM
Jere Hummelgaard
Dec 20, 2013 02:03 PM
49 Ford F-1
Jun 7, 2012 10:03 PM
fordguy622
Aug 2, 2009 10:31 PM
