Hi all, I started looking for alternative gauge centers when I found out the the Edge CTS3 can not support sensors other than 0-5v, can not support other screens, and is just generally way to limiting(and expensive).
I found Onegauge and it looks pretty cool, basically a torquepro obd2 reader that also has a breakout board for any sensor you may want to hook up.
Anybody have any experiences with these? Any reason I shouldnt go with something else over the Edge? Just looking for general discussion and user experiences.
Sounds like torquepro is the way to go. Anyone else know of anything that uses torquepro to get information through the obd2 and also lets you add additional sensors?
Well id like to be able to see any values for sensors that the pcm knows.
But also I have 4 extra tanks I need to see the sending unit data for, couple extra thermistor readings I need, at least one extra thermocouple reading for EGT, a few extra pressure readings, stuff like that.
