$135.00-145.00 labor with 1 hour min around me. Was 125.00 before covid. Replacing a mirror housing or removing to replace just signal will be charged as a 1 hour job although it takes much less time.
I've had to replace mine twice and can't see the dealer charging more than an hour. Around here that would be $165 maybe $185 now. I bet Ford only pays .4 (or less) of an hour if it were a warranty repair.
I smashed the singal light lens on mine when I was a bit too close to some construction fencing. I should get off my **** and order the lens and figure it out.
Ugh, my last one spoiled me then as it was always eating bulbs.
These should last longer, so as long as you or someone else doesn't damage the lens you may never have to deal with replacement. The two I replaced were do to damage, one I believe took a rock, the other appeared to be caused from another vehicle making contact.
Ha. Go ask the dealership for a cost to replace one single spark plug. The response will leave you scratching your head.
