Seized Spark Plug 352FE help!
Old Jan 10, 2023 | 08:52 PM
Charlie_67's Avatar
Charlie_67
4th Gear
Changing out spark plugs in my 1967 F250 and discovered the plug in cylinder 8 is totally seized. Who knows how long it’s been stuck in there.
Anyway I feel like I have tried everything. WD40, PB Blaster, air impact wrench, breaker bar with 5ft extension for leverage. It’s not budging.
what am I missing? Is this common in FE’s? What else can I try?
Old Jan 11, 2023 | 06:09 AM
Scramblizer's Avatar
Scramblizer
Sounds like you tried most of the options I know except for the magic of using a heat gun and / or the 50/50 acetone/ATF tricks ... 🤔
https://www.ford-trucks.com/forums/1...etone-atf.html
Cheers and good luck! 🤞 Markus
Old Jan 11, 2023 | 06:21 AM
robertrpeak's Avatar
robertrpeak
SAy you tried all those things? Did you give them enough time to soak thru and down the threads? May take hours/days to reach full soak.... run the engine up to temp then spray...it'll come out soon!!
Old Jan 11, 2023 | 08:27 AM
1964 Model's Avatar
1964 Model
Time is your friend when soaking, threads to break them loose. You probably already knew that, but i thought I would mention it.
I use a mix called Ed's Red to break bolts, as it works about the same as Kriol and its cheaper. Its actually a concoction, from the gun hobby, used as a cleaner.
There are a few different mixes, but its basically a 1/3 mix of non synthetic Trans Fluid, (old type F trans fluid works well) Acetone, and Diesel or Kerosene.
Some leave out the Acetone and use mineral spirits, so it is more paint safe.
Give it a day or 2 so it can soak in, before you try to loosen again.
Worst case, if you have a cutting torch, use that you put some heat on it. Cycling it from hot to cold will some time break the bond, and then heat and try to remove while hot.
Lots of luck.
Old Jan 11, 2023 | 08:44 AM
Crop Duster's Avatar
Crop Duster
Run the engine until it's hot. Take your breaker bar and socket put it on the plug and give it a yank! If it breaks the damn thing needed fixen anyway.
Old Jan 11, 2023 | 09:47 AM
351Cleveland C4's Avatar
351Cleveland C4
Keep soaking it with PB blaster daily. After a week, get it hot and put an impact wrench on it. The percussion will help break it loose.
Heating and cooling will also help. CRC makes a can of freeze-off. useful at times like this
Old Jan 11, 2023 | 05:40 PM
CarterDawson's Avatar
CarterDawson
Drop all those lubricants and go buy Kroil. Very fast working and works way better than all those combined. Soak them all day and try the next day.
Old Jan 11, 2023 | 06:31 PM
RTT's Avatar
RTT
This remedy takes a little time , maybe : Drink 11.75 regular beers ( real beer no light wimpy beer ) .
Do not **** for 2.75 hours minimum the longer wait the better
Then start truck , get a 6 foot ladder , climb to top quickly , pull down pants & "**** on the number one spark "
Spark plug may not come out but you will feel MUCH BETTER
A REAL MECHANIC WILL **** ON ALL OF THEM BY THE FIRING ORDER
Old Jan 11, 2023 | 07:18 PM
351Cleveland C4
Old Jan 12, 2023 | 04:26 PM
fe390pc's Avatar
fe390pc
Well that went right off the rails..... Heating the plug is good but be carefull, you don't want to overeat the head. Unless you **** on it the keep it cool
Old Jan 13, 2023 | 10:32 AM
RTT's Avatar
RTT
I have always heard since a kid , " I'm so mad I could **** on a spark plug "
Old Jan 13, 2023 | 07:02 PM
'65Ford's Avatar
'65Ford
My strategy is to run it to operating temp (assuming it runs), soak the plug with PB Blaster, let it cool over night and repeat each day for 5-6 days. Then use a regular plug socket and ratcheting wrench. If and when it starts to move, work it back and forth (tightening and loosening) several times and gradually work it out. Sometimes if it starts to move and you muscle it all the way out the rust will ball up and wreck the threads in the hole.
Before the plug is completely out, use compressed air to blow away dirt and rust.
Then use a spark plug thread chaser gently to clean the threads in the hole.
Remember the anti-seize before installing new plug.
Old Jan 13, 2023 | 08:05 PM
Christmas's Avatar
Christmas
Not a good idea to use anti-seize or any such product on spark plugs or senders. Such things need a good ground.
Old Jan 13, 2023 | 10:32 PM
1964 Model's Avatar
1964 Model
Maybe not then, on the anti seize on the plugs? I have fought a few stuck plugs, where these older style plugs were used, so I coat mice lightly.
Power steering and factory air on the 70's trucks, made fighting a stuck one a real bummer.
I cant say that i ever had any drivability issues doing it, or can really say that it prevented a stuck plug in the future. I just always brushed on a coat of it, with the hope of preventing headaches later.
Since there is always a first, and I learned a long time ago to never say never, with women or mechanical things.
Brad
Old Jan 14, 2023 | 05:22 AM
RTT's Avatar
RTT
I read it to use very small amount of anti-seize so it will not seep into combustion chamber .
I use a small amount of oil .
