Transmission Options?
As far as the 6.xx gear, I know it's an offroad gear for most, but do you think the 2.47 rear might make it closer to 2nd with like a 3.55 or 4.10 rear? My current setup makes it barely possible to tow my 1200lb boat, so I just want to make sure towing closer to 5k will be fine
With a t18 or t19 in first gear it has a 6.32 ratio. With your 2.47 rear the final ratio in 1st will be 6.32 x 2.47 = 15.61
If you had a 4.10 gear with the transmission you have now, 3.39 x 4.10 = 13.89 So the 6.32 gear is still steeper than having a 4.10 rearend.
non-removable carrier (8.8" ring gear), 2.47 ratio
non-removable carrier (8.8" ring gear), 2.73 ratio
non-removable carrier (8.8" ring gear), 3.08 ratio
non-removable carrier (8.8" ring gear), 3.55 ratio
non-removable carrier (8.8" ring gear), 4.10 ratio
removable carrier (9" ring gear), 2.47 ratio
removable carrier (9" ring gear), 2.75 ratio
removable carrier (9" ring gear), 3.00 ratio
removable carrier (9" ring gear), 3.25 ratio
removable carrier (9" ring gear), 3.50 ratio
removable carrier (9" ring gear), 4.11 ratio
https://www.novak-adapt.com/knowledg...manual/t18-t19
Whatever you get, with that very low 2.47 gear it's going to be a little weird. I don't know what your plans are for getting another transmission, but if you got a later 80's truck that has a 5 speed and a higher ratio rearend that you can swap in at the same time, that would put your truck back to a more "normal" setup with low enough gears to tow and a overdrive for fuel mileage. Getting a donor with the same wheelbase would guarantee you had the driveshaft and anything else you needed for the swap.
Here are the transmissions available in 1985.
MT, 4 speed, New Process manufactured, 4x4
MT, 4 speed, Warner manufactured, 4x2, 12" extension
MT, 4 speed, Warner manufactured, 4x2, 4" extension
MT, 4 speed, New Process manufactured, 4x2, 4-1/4" extension
MT, 3 speed
AT, 4x2, C6
MT, 4 speed, New Process manufactured, 4x2, 12-1/4" extension
AT, 4x2, AOD transmission, 8-302 (5.0L), 10-1/4" extension housing
AT, 4x2, AOD transmission, 8-302 (5.0L), 11-1/4" extension housing
AT, 4x2, AOD transmission, 6-300 (4.9L)
AT, 4x2, C5
MT, 4 speed, Ford (Overdrive) manufactured, 4x2
MT, 4 speed, Ford (Overdrive) manufactured, 4x4
MT, 4 speed, Warner manufactured, 4x4
AT, 4x4, AOD (8-302, 5.0L)
AT, 4x4, C6
I picked a New process with a 4 1/4" extension and saw one in Pa for $400. I picked the New Process with the 12 1/4" extension and got a lot more hits and selection in Pa. Got a lot of hits with both Warner 4 speeds, and they are about the same price.
