Tire clearance
Old Nov 15, 2022 | 06:39 PM
rowdyredneck's Avatar
rowdyredneck
Tire clearance
I'm doing a bunch of work on my '87 F150 4x4 short bed. It currently has stock suspension with 31x10.50 tires on 8 inch rims. The front hangs about 3" lower than the rear so I want to level it. I plan on installing 2" lift springs in the front + 2" radius arm and axle drop brackets. I'd like to run a wider tire. Will a 33x12.50 on 10" rims clear without rubbing using this combination? Does anyone have pictures of this setup?
Old Nov 15, 2022 | 07:41 PM
Conanski's Avatar
Conanski
At full lock they will touch the radius arms at the back and maybe the bumper or front sway bar so you will lose a little turning radius. To combat this get rims with no more than 3.5-3.75" backspacing, that creates more room on the inside but requires more room on the outside, the bumper may need to be spaced out 1" or so... not a big deal. With the lift you probably won't need to trim fenders.
Old Nov 16, 2022 | 05:08 AM
rowdyredneck
How about 32x11.50 on 10" rims? That's the other combination I was considering. I know a lot of people don't recommend mounting that size tire on a 10" rim because the bead grip won't be as secure but this truck is street driven only so it won't be a problem.
mxracer3276
Mar 3, 2010 07:27 PM
70torino429
Aug 13, 2009 10:00 AM
Dutch123
1978 - 1996 Big Bronco
Sep 20, 2003 07:31 PM
thayer69
Apr 10, 2003 03:02 PM
aj5601
Nov 16, 2002 09:18 AM
