cold running 4.9
Old Oct 26, 2022 | 06:53 PM
Abbeywigglebutt1's Avatar
Abbeywigglebutt1
1st Gear
Angry cold running 4.9
Runs in low ist quarter of guage and runs too fat to smog. This is 92 w/FI Can hotter thermostat actually end u gaining fuel mileage? Tried every thing else
Old Oct 26, 2022 | 07:06 PM
Conanski's Avatar
Conanski
That is normal for these trucks
So it's got problems, have you pulled codes?
This is your first post so you're going to have to elaborate... lots.
Old Oct 28, 2022 | 07:03 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It should have a 195° F thermostat. What is in there now?
Old Nov 2, 2022 | 02:18 AM
TexasGuy001's Avatar
TexasGuy001
That gauge reading is how every one of these trucks I've ever seen are.
You definitely want the correct thermostat which is 195 sometimes labeled 192 I think. I've seen 180 thermostats cause failed sniffer test with not much different gauge reading when warmed up.
You can try an IR thermometer pointed at the thermostat housing when its warmed up and see what that reads.
Also, does the heater blow hot air or just warm air?
Get a Innova 3145 code reader.
GarrettBabb
Jul 17, 2013 10:31 AM
kvfrider
2004 - 2008 F150
37
Feb 10, 2009 06:36 PM
golfboy17
Nov 13, 2003 04:09 PM
73tank
Aug 10, 2003 08:11 AM
russs
Mar 7, 2001 09:05 PM
